Where is the Fulcrum for a Boat Hit by a Wave?
  • Context: Undergrad
  • Thread starter Thread starter Ilan
    Fulcrum
The discussion revolves around the dynamics of a boat when it is hit by a wave, specifically focusing on the concept of the fulcrum point around which the boat rotates. Participants explore the relationship between the center of buoyancy (C of B) and the center of gravity (C of G) in the context of boat motion and stability.
  • One participant suggests that the righting moment after a wave impacts the boat causes it to rotate clockwise, questioning the point of rotation.
  • Another participant asserts that the center of buoyancy remains stationary, indicating that the boat's motion can be treated as pure rotation about this point.
  • A different viewpoint notes that some hull designs, like catamarans, have a center of buoyancy that shifts outboard when the boat heels, complicating the notion of a fixed fulcrum.
  • One participant references an article on metacentric height, implying that such calculations are standard in maritime contexts, particularly for cargo ships.
  • Another participant argues that most boats have a center of buoyancy that moves, challenging the idea that a circular hull would keep the center of buoyancy stationary unless it is at the center of the circle.
Participants express differing views on whether the center of buoyancy remains stationary or moves during the boat's motion, indicating that multiple competing perspectives exist without a clear consensus.
Participants discuss the implications of hull shape on the center of buoyancy and the conditions under which it may shift, highlighting the complexity of the topic without resolving the debate.
This discussion may be of interest to individuals studying naval architecture, marine engineering, or those involved in animation and simulation of fluid dynamics related to boats.
Ilan
Hi,
I'm making an animation of how a boat behaves when hit by a wave. This is how it looks like after the wave:
(see attachment)
At this point there should be a righting moment that tries to balance the boat by turning it clockwise.
Which point does the boat rotate around?
I'm not sure because the forces act on the C of B and the C of G and so I was thinking it would be the black dot, but shouldn't the C of B not move since it is a circular bottom?
What do you guys think?
Thanks!
EDIT:
Ok so I tried to animate it:
http://www.ironwhisk.com/wordpress/wp-content/uploads/2012/12/test.swf
If this motion is correct, then does that mean that the fulcrum moves? Why?
Yeah, the centre of buoyancy remains stationary. (its, basically just the centre of geometry of the part inside the liquid, and hence as shown in the animation remains unaffected as boat moves).
So the motion of the boat can be considered as pure rotation about its C of B. (like rotation about a pivot)
Some hull shapes are designed so that the CoB moves outboard when the boat heels over. Consider a catamaran. With the mast vertical the CoB is mid way between the two hulls. With one hull "flying" the CoB has moved to the hull still in the water.
Most boats, including this one, will have a center of buoyancy that moves. The circular hull would only enable a stationary center of buoyancy if it was at the center of the circle. The wiki link explains it well.
  • · Replies 26 ·
  • · Replies 33 ·
