Forces on ropes connected to a slanted ceiling
  • Context: Undergrad
  • Thread starter Thread starter SweatingBear
    Forces
The discussion revolves around the forces acting on two ropes connected to a slanted ceiling, specifically whether the tension in the ropes varies with the angle of the ceiling. Participants explore the implications of equilibrium, torque, and symmetry in the context of this scenario.
  • Some participants claim that the forces on the ropes will equal 150 N each, regardless of the ceiling's slant.
  • Others suggest that the solution may depend on whether the ceiling is slanted or the lengths of the ropes differ.
  • There is a discussion about the necessity of considering torque in the analysis, with some arguing it may not be required.
  • One participant proposes that if the upper part of the setup is obscured, the forces would still need to balance, leading to equal tensions in the ropes.
  • Another participant explains how to use torque to find the tension, indicating that the tension in each rope must equal half the weight of the person being supported.
  • Some participants express uncertainty about the role of torque and whether it is essential for solving the problem.
Participants express differing views on whether the slant of the ceiling affects the tension in the ropes. While some believe the tension remains constant at 150 N, others raise questions about the implications of torque and the geometry of the setup, indicating that the discussion remains unresolved.
There are limitations regarding assumptions about the system's geometry and the definitions of equilibrium and torque that participants have not fully resolved.
SweatingBear
Hey forum.
So I was posed the question whether the forces on two ropes will vary or not depending on if the ceiling from which they are hanging is slanted or not. Here's a picture depicting the scenario:
I claim they'll equal 150 N respectively, independent of the ceiling slanting or not. But I am not sure how to motivate this (mathematically and/or conceptually). Do you guys have any idea?
Picture-source:
Pretend the top of the picture was covered up so you had no idea about what the ropes attached to. Would it change your solution?
Do you know how to solve this problem in the first place? Assume a horizontal ceiling, if it helps. (Consider torques acting on the rod the girl hangs from.)
No, I do not think it would. The upward-forces would still have to cancel the downward-forces. But if it was slanted, I am not sure, albeit inclined to believe that the respective forces still equal 150 N. Got any idea?
Well, in that case the upward-directed forces must equal the downward-directed forces because equilibrium in the system reigns.
That's true, but only part of the story. For equilibrium, the torques about any point must add to zero as well. You can use that fact to solve for the tension in each rope.
Hm, I see your point. But I do not think that is necessary because in that part of the video-series, he has not even mentioned torque. So I am supposing that the question can be answered without respect to torque.
But, if do have to consider torque, I am not really sure how the calculation really goes; care to show?
SweatingBear
Is it the slant of the ceiling or the differing lengths of the two ropes that has you wondering?
How does force transmit itself from one location on the rope to the next? Does the tension in a rope vary along its length?
If the roof was so high that you could not tell whether the roof was slanted or not by just looking at it straight up to determine an incline, could you detemine the force at each end on the bar?
Cut the girl vertically in half and attach each half to each end of each rope and remove the horizontal rod that she hangs from. The tension in each rope is the same regardless of the slope of the roof assuming equal halves.
Does this help? Sorry for the gruesome picture above.
figuratively, or literally ( in which case I do not see the gory details :-p )
Great explanation - works for me.
256bits said:
SweatingBear
Hm, interesting thought. I suppose they, in that case, would have to make up 150 N respectively.
Yes, quite helpful. :)
Concluding remark: Regardless of if the ceiling is slanted or not, the force on each rope is half of the persons weight i.e. 150 N (respectively).
Sure, you can just appeal to symmetry, which is what I was leading you towards with my suggestion to pretend you couldn't see the upper part of the diagram. (It doesn't matter!) Since the bar is horizontal and the girl is even suspended (her weight acting right in the middle), you can conclude that the rope tensions must be equal.
If you wanted to use torque to figure out the tension in the rope, here's how it goes. We'll use the left end of the bar as the pivot point. The torque from the girl's weight, which acts in the middle of the bar, exerts a clockwise torque of WL/2 (where L is the length of the bar). The right hand rope exerts a counterclockwise torque of TL, where T is the tension. Those torques must balance to have equilibrium, so WL/2 = TL and thus T = W/2. The tension in the right hand rope must equal half the weight. The same logic applies to either end, of course.
Fantastic answer, thank you Doc Al!
  • · Replies 86 ·
10K
  • · Replies 32 ·
