Fields of a very short laser pulse, pulse a fraction of wavelength.
The discussion revolves around the feasibility and implications of generating very short laser pulses, specifically those on the order of one wavelength in length. Participants explore the theoretical underpinnings, particularly in relation to Maxwell's equations, and the effects of such short pulses on the electromagnetic field and frequency spectrum.
  • Some participants inquire whether Maxwell's equations allow for solutions corresponding to very short laser pulses and suggest approximating such solutions using plane electromagnetic waves modified by spatially decaying exponentials.
  • Others argue that while Maxwell's equations do not prohibit the creation of short pulses, the practical challenge lies in their experimental realization, noting that propagation through dispersive media may lead to pulse broadening unless compensated by nonlinear effects.
  • Several participants propose specific forms for electric and magnetic fields to test against Maxwell's equations, highlighting that the divergence conditions for these fields must be satisfied.
  • One participant discusses the relationship between pulse length and bandwidth, explaining that shorter pulses result in broader frequency spectra, referencing the Fourier transform of pulsed waves.
  • Another participant elaborates on the concept of multiplying a pure waveform with a gating signal to create short pulses, emphasizing the resulting convolution in the frequency domain that leads to a spread of frequencies.
Participants express differing views on the implications of short pulses for electromagnetic theory and the practicalities of their generation. There is no consensus on the best approach to modeling these pulses or the effects they produce.
Some discussions touch on the limitations of the proposed models, such as the need for components in specific directions for electromagnetic waves and the assumptions underlying the Fourier transform analysis.
This discussion may be of interest to those studying electromagnetic theory, laser physics, or wave propagation, particularly in the context of short pulse generation and its implications for frequency analysis.
Spinnor
Scientists can produce laser pulses of order one wavelength in "length" see,
http://www.bbc.co.uk/news/science-environment-19489384
Do Maxwell's equations admit solutions of such short pulses?
Can one approximate such a solution by multiplying a plane electromagnetic wave by the appropriate space decaying exponentials?
Thanks for any help or suggestions!
Science news on Phys.org
From a purely classical EM theory viewpoint, you only need a temporally equally short 'pulse' of current at some point and the only thing that Maxwell's equations do is prescribe how the resulting em-field propagates. But they do not forbid you to create any kind of however short temporal profile if you manage to do so experimentally: Which is probably the difficult part.
Also, after propagation in a dispersive medium, the pulse will broaden (If this is not compensated by nonlinear effects).
A short pulse will be very broad in the frequency domain so i would not think that it makes sense to approximate them with a plane wave.
Try E_x = cos(-t)cos(z)exp(-x^2)exp(-y^2)exp([z-t]^2)
B_y = cos(-t)cos(z)exp(-x^2)exp(-y^2)exp([z-t]^2)
in Maxwell's equations and see what you get?
You don't have to as both the divergence of both E_x and B_y above are not equal to zero as they should be for a electromagnetic wave far from charges. ---> Both B and E need a component in the z direction?
See J.D. Jackson, 2nd ed. page 333, problem 7.20 for a solution closer to what you want.
Take Jackson's approximate fields for a circularly polarized wave of finite beam width, set ω and k equal to one, and multiply each by exp([z-t]^2) and see how well these new fields satisfy Maxwell's equations. Is this something the software Mathematica would handle?
Edit, that should be exp(-[z-t]^2) above.
Would a better attempt be to take Jackson's approximate solution above and multiply by an unknown function of (z-t), f(z-t), (where f(z-t) decays rapidly from the line z-t =0) and apply Maxwell's equations, one might then find differential equations the unknown function f(z-t) must satisfy?
Thanks for any help!
This is perhaps more fundamental than Maxwell's equations, being really to do with wave theory, which applies to electromagnetic, sound and all other propagating waves equally. All that happens as the pulse is shortened is that the bandwidth increases. This can be seen by taking the Fourier transform of the pulsed wave of different lengths. An infinitely long pulse of monochromatic radiation has a zero bandwidth. An infinitely short one has an infinite bandwidth which in turn means it cannot be considered monochromatic. Chopping up monochromatic light into short pulses creates a spread of frequencies centred around the original monochromatic frequency.
why Chop up monochromatic light into short pulses creates a spread of frequencies centred around the original monochromatic frequency? what effect cause the spread?thank you!
An infinitely long waveform is pure and unadulterated. If however, you want a short pulse of only (say) three wavelengths, you are essentially multiplying that pure waveform with another gating signal in the time domain, in this case a square pulse three of the wavelength in length; this pulse allows those three wavelengths through and blocks the rest. That gating signal has its own frequency spectrum.
That means we end up with two separate signals multiplied together in time, each with its own frequency spectrum. Multiplication in time, when converted to the frequency domain, becomes convolution (or 'spreading') in frequency, where the frequency spectrums of the two source signals spread each other out to make a more complex spectrum for the composite signal.
(note that although convolution is generally thought of as "spreading", it can do the opposite under certain circumstances, but that does not apply in this case).
