Pipe Freezing Time: 150NB Steel Pipe in -15C
A 150NB stainless steel pipe insulated with 50mm of rockwool may not prevent freezing during five consecutive days at -15°C, especially with stagnant water. The maintenance temperature of the potable water is 5°C, and the pipe runs 1.5m horizontally with a 2.5m vertical climb to a storage tank. Experts suggest that trace heating is likely necessary, as the insulation alone may only provide freeze protection for around 9-10 hours under static conditions. Continuous flow could mitigate freezing risks, but the insulation's effectiveness diminishes significantly in extreme cold. Overall, additional heating measures are recommended to ensure the pipe remains unfrozen.
Padnail
I am trying to ascertain if a 150NB Stainless Steel pipe lagged with 50mm thick insulation would also require to be trace heated. The insulation used is rockwool. The parameters are that the pipe must not freeze solid given 5 straight days of -15 C with static flow. Wind chill is negligible. The pipe contains potable water. Any information would be greatly appreciated.
What's the maintenance temp of the potable? The length of the line?
At first glance, though, I'd say you'll have to heat trace that line. If your design parameter is multiple consecutive days at or around -15 C, then I'd say your insulation is not going to be sufficient.
References for you to look at:
Chromalox 1 (by Proheat Inc.)
Chromalox 2
Cheers Travis. Appologies for the lack of detail. The working temperature is 5 C and the pipe runs 1.5m horizontal with a 2.5 m vertical climb feeding a storage tank. I similarly suspect it may require trace heating but do think it is borderline.
oh, that's a short run of pipe. Are you not worried about the storage tank? Or is that heated?
Either way, with 50 mm rockwool insulation, you're looking at a timeline of hours at that temp, not days. The calcs in the reference assume a few things, but they are fairly good estimates. There's no way you'll get 5 days of -15C temps out of that. More like half a day, if that.
A back-of-the-envelope calc indicates that you'll likely have freeze conditions in ~9-10 hours, probably a bit longer considering these numbers are factored. That's with stagnant water. If it's constantly running, the insulation is fine.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
17K
11K
9K
22K
