Pattern recognition using splines
  • Context: Graduate
  • Thread starter Thread starter Charles49
    pattern recognition
The discussion revolves around the challenge of connecting overlapping curves in an image where certain segments are missing. Participants explore methods for using splines to reconstruct these curves based on visual cues, with a focus on the implications of the problem being ill-posed.
  • One participant seeks a method to connect curve segments in a single image using splines, emphasizing the need for a program that reflects human visual perception.
  • Another participant questions whether the image is singular or part of a set, noting that methods may require adjustments based on the specific images involved.
  • It is mentioned that filling in broken segments of curves is an ill-posed problem, lacking a clear definition of correctness, which can vary based on subjective evaluation.
  • A suggestion is made to create a training set of images to help refine the algorithm for curve completion.
  • Keywords for further research are proposed, including "computer vision curve completion" and "computer vision occlusion," among others.
  • A paper titled "A Tangent Bundle Theory for Visual Curve Completion" is recommended as a resource.
Participants express varying opinions on the nature of the problem and potential methods, indicating that there is no consensus on a definitive approach or solution.
The discussion highlights the ill-posed nature of the problem, which complicates the development of a universally applicable method for curve completion.
Charles49
I am supposed to have an image consisting of overlapping curves. What I have is an image where the curves are missing certain segments of them. However with the human eye we can tell that certain segments are part of the same curve. (see attached figures). I want to know how I can write a program to connect curves with splines that visually we know are related.
In other words if I have a bunch of segments, how do I connect them with splines so that I get what my human eye is telling me is the correct match.
This is a difficult problem so any reference would also be very helpful.
Do you have a single image? Or a set of images drawn in a similar manner - say by the same person or process? Or are you looking for a method that works on all sorts of images?
There are no known methods that work on all sorts of images without your having to fiddle with adjusting them to the particular images you have.
Known methods that work on set of similar images would require some sort of tweaking and trial and error. For example, you might have to create a "training set" of images that gave the image and the correct fill-in. Then you'd need an algorithm to fit the method's parameters to the training set.
Fillling-in a curve from broken segments is, in the jargon of mathematics, an "ill posed problem". The statement of the problem does not define how to judge whether a given answer is correct or incorrect. Whether a method works or not depends on the opinion of the person evaluating it and people's opinions can vary depending on their artistic taste or what they want to accomplish once the curves are filled-in ( like detect what part of the image is a picture of a dog etc.).
I'm ducking specifics for now. I think it will be easy to find many papers on the web that show methods of filling-in broken curves. They will work on the set of images they werel developed for and they may or may not work on your images. Since this is the math section of the forum, the first thing to get straight is that you don't have a well posed problem. That's no reason to despair. For example, the simplest statement of the problem of reconstructing anatomy from MRI data is an ill-posed problem, but people develop useful images by adding conditions to the problem that are precise enough to define what a correct solution is.
Hi Stephen,
I have a single image. It is computer generated from a series of images. Since my background is not in computer science, could you please give me a few keywords that I can google to make my search for possible answers more effective? I am looking up training set now.
Charles
For the more general problem of missing or blocked pieces of an image:
For a little known top-down down approach to image recognition by the researcher Mike Alter:
computer vision Upwrite
You could also use "image recognition" instead of "computer vision".
Thank you very much.
Here is a good paper: A Tangent Bundle Theory for Visual Curve Completion
by guy ben-yosef and Ohad ben shahar
