Throttling Ideal Gas: Is Temperature Change Involved?
  • Context: Undergrad
  • Thread starter Thread starter starryskiesx
    Gas Ideal gas
The discussion clarifies that when an ideal gas is throttled through a capillary into a vacuum, it does not experience an immediate temperature change. However, the process is complex and depends on the setup and duration of the experiment. The gas initially cools as it expands due to work done against external pressure, while the gas in the capillary equilibrates with its surroundings. Ultimately, after sufficient time, the gas may return to a uniform temperature, but this is contingent on the specific conditions of the experiment.
  • Understanding of the Joule-Thomson effect
  • Knowledge of thermodynamics principles related to ideal gases
  • Familiarity with gas expansion processes
  • Basic concepts of kinetic energy and work in physics
  • Research the Joule-Thomson effect in detail
  • Study the thermodynamic properties of ideal gases
  • Explore practical experiments involving gas expansion and temperature changes
  • Investigate the impact of different capillary sizes on gas behavior
Students and professionals in physics, engineers working with gas systems, and anyone interested in thermodynamic processes involving ideal gases.
starryskiesx
A quick question about throttling:
I've read that for an ideal gas, if you force it through a capillary into a vacuum and allow it to equilibrate, it will experience no temperature change. I was wondering if this is correct, and if anything changes when you're forcing it through with a piston for example.
Science news on Phys.org
Even with an ideal gas, this sort of thought experiment is very misleading and about impossible to make in practice...
First, the gas would take the temperature of the capillary.
Then, the gas that at some time remains in the bottle pushes the gas that goes out, gives a work, and loses internal heat. It cools down, while the flowing gas receives some work that it may transform into internal heat, depending on the experiment, or into kinetic energy, or into work against the external pressure.
It's only after a very long time that the gas may regain some form of equilibrium - between the part flown first out and the part flown last - that the temperature is uniform, and then, with a ideal gas, you may observe the same temperature as before the expansion.
So it's much more a question of setup and time than of the gas being ideal. In two words: be careful.
  • · Replies 60 ·
11K
  • · Replies 22 ·
  • · Replies 109 ·
10K
  • · Replies 35 ·
  • · Replies 19 ·
