Substance evaporation temperature
  • Context: Undergrad
  • Thread starter Thread starter indianaronald
    Evaporation Temperature
Substances evaporate at their saturation temperature (T(sat)) corresponding to the prevailing pressure, as established in thermodynamic principles. For instance, when a refrigerant in a pressurized container is released, the pressure decreases, leading to a drop in T(sat), which dictates the temperature at which evaporation occurs. Evaporation is a cooling process that continues until thermal equilibrium is reached at the surface, preventing evaporation at higher temperatures under lower pressure conditions.
  • Understanding of thermodynamics, particularly phase changes.
  • Familiarity with saturation temperature (T(sat)) and its relationship with pressure.
  • Knowledge of refrigeration cycles and their components.
  • Basic principles of heat transfer and thermal equilibrium.
  • Research the Clausius-Clapeyron equation to understand the relationship between pressure and temperature in phase changes.
  • Explore the properties of refrigerants and their phase diagrams.
  • Learn about the principles of heat exchangers in refrigeration systems.
  • Investigate the effects of pressure on boiling and evaporation processes in various substances.
Students and professionals in thermodynamics, chemical engineering, and HVAC (heating, ventilation, and air conditioning) systems, as well as anyone interested in the principles of phase changes and refrigeration technology.
indianaronald
Can a substance only evaporate at the T(sat) at that particular pressure and why not even at a higher temperature?
Example of a refrigerant at room temperature, pressurized container. But when it's opened, the P falls and T(sat) falls, so it goes to that T(sat) temperature to evaporate. But why? Why not evaporate at the room temperature itself?
Science news on Phys.org
Evaporation reduces the temperature of the surface until you have an equilibrium (or something close to it) at the surface.
  • · Replies 32 ·
  • · Replies 109 ·
10K
  • · Replies 28 ·
