How can I power a Peltier Thermoelectric Cooler
To power a 15mmx15mm Peltier Thermoelectric Cooler requiring 1 Amp at 0.8 Volts, a suitable DC power supply is necessary. A recommended model is the Model 442-1A Temperature Controller, which is compatible with similar devices. However, specific purchasing information for this model is not readily available, and users are encouraged to check with their supplier for options. Additionally, using resistors to achieve the required voltage is a possibility, though guidance on implementation is needed. Overall, sourcing the correct power supply is crucial for the successful operation of the Peltier device.
zmillerkoren
Hi I recently purchased a small (15mmx15mm) Peltier Thermoelectric Cooler/Heater. I am using this for a prototype of mine but I can't find a way to power it. The specs are 1Amp 0.8Volts.
I was just wondering if anyone knew where to find a power supply (DC) to power it. I could also use resistors, but I'm not quite sure how to do so. This all has to fit within a size of about the length of a pencil with a width of a ruler (cylinder).
Any input will be greatly appreciated, Thanks,
Zach
zmillerkoren (Zach), Welcome to Physics Forums!
The power supply you need is: Model 442-1A: Temperature Controller
It is used in this detector:
Model ID-441-C
InGaAs Near Infrared Detector
with Preamplifier and Thermoelectric Cooler
http://www.piacton.com
I could not find how or where to buy it, however. Princeton Instruments and Acton Instruments sites were no help. Wherever you acquired your Peltier Thermoelectric Cooler/Heater ought to be able to either supply one, or tell you how to locate it.
Cheers,
Bobbywhy
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
