Help Evaluating Integral with Euler's Formula
  • Thread starter Thread starter jaygatsby
    Integral
The discussion revolves around evaluating an integral involving a Fourier transform, specifically the integral of the product of an exponential decay function and a sine function, expressed with complex exponentials using Euler's formula.
  • The original poster attempts integration by parts and using Euler's formula to express the sine function as complex exponentials but encounters difficulties. Some participants suggest using standard integral tables, while others question whether the integral should be solved without such resources.
The discussion is ongoing, with participants exploring different methods of integration and questioning the appropriateness of using integral tables versus manual evaluation. There is no explicit consensus on the best approach yet.
Participants note that the problem is from a textbook and is not a required homework problem, which raises questions about the expectations for solving it. There is also mention of specific conditions for the integrals involving trigonometric functions.
jaygatsby
This is not a homework problem, but a problem in the textbook that is not required. I am doing this to get a handle on the topic.
I am evaluating a Fourier transform, without tables, and need to evaluate this integral:
[tex] \int e^{-t} * sin(2 \pi f_c t) * e^{-j2 \pi ft} dt[/tex]
I have tried two methods: 1) integration by parts, and 2) integration after expressing the sine function as a complex exponentials. I get stuck in both cases.
The asterisks are there to assist with clarity of spacing. Thanks for any help you can provide,
J
Use Euler formula to get exp(-t)*trig function. This is a standard integral (find in table).
Trig function: sin(at), integral = a/(1 + a2)
cos(at), integral = 1/(1 + a2)
(a > 0 for both)
Thanks, I did try Euler's formula but then worked the integral out manually (attempted to...)
So this integral I would find in the table exclusively, and never try without a table? The way the drill is stated in the book (not a homework problem.), I wonder if I am to work it out without a table.
Thanks,
J
You can integrate by parts twice to get an equation involving the original integral.
I(exp(-t)cos(at)) = 1 + aI(exp(-t)sin(at)) = 1 - a2I(exp(-t)cos(at))
Similarly for sin(at) integral.
Thank you
  • · Replies 105 ·
13K
