Assumed violation of physics - Heat vs. Work
  • Context: Graduate
  • Thread starter Thread starter Low-Q
    Heat Physics Work
The discussion revolves around the potential interaction between heat engines and heat pumps, particularly in the context of energy efficiency and the possibility of using a heat engine to power a high coefficient of performance (COP) heat pump. Participants explore theoretical setups, efficiency calculations, and the implications of the second law of thermodynamics.
  • Some participants propose that a heat engine could be used to power a heat pump, suggesting that the heat pump's efficiency could enhance the overall energy output.
  • Others argue that the efficiency of heat engines and heat pumps is fundamentally limited by the temperature differences between reservoirs, which could negate the proposed benefits.
  • One participant emphasizes that maximum thermodynamic efficiency is dependent on the temperature difference and that arbitrary efficiency figures cannot be used to validate claims.
  • Another participant provides a calculation showing that for a heat engine to achieve 70% efficiency, the required temperatures of the reservoirs would be unrealistic, challenging the feasibility of the initial proposal.
  • There is a discussion about the implications of using a heat pump with a high COP and how it relates to the efficiency of the heat engine, with some questioning whether such a setup could theoretically work under ideal conditions.
Participants express differing views on the feasibility of using a heat engine to power a heat pump, with some supporting the idea and others strongly contesting it based on thermodynamic principles. No consensus is reached regarding the validity of the proposed interactions between the systems.
Participants note limitations in their discussions, including the dependence on specific temperature ranges and the assumptions made about efficiencies. The calculations presented rely on idealized conditions that may not be achievable in practical applications.
  • #61
Low-Q said:
To make this work we need a third reservoir. The ground for example. Its temperature will not change as much as the air temperature outside. At very hot or very cold days, the heat engine can be ran by those two reservoires. It powers the heat pump which removes heat from the house at warm days, and supply heat to the house at cold days. Lucky for us, the heat engine will increase its efficiency as the temperature difference is increasing.
So you would use the temperature difference between the air and the ground to drive a heat engine which would power a heat pump to heat or cool a house? I see no reason that couldn't be done.
Science news on Phys.org
  • #62
DaleSpam said:
That is exactly what I assumed when I analyzed it above. As I showed above, even for an ideal heat engine and heat pump you would have to use all of the work from the heat engine to run the heat pump. For a real heat engine you will get even less energy and for a real heat pump you will need even more.
I still don't have any real confidence that you understand the proposal represented by the diagram. If you really want to discuss it I think it would probably be necessary to go back to the beginning.
A mathematical analysis might prove to be quite interesting and useful but so far you have chosen figures that seem inapplicable to the scenario described, so I'm not sure you really understand the proposal.
It doesn't seem to me that you can really prove that x - y = 7 by showing that q - z = 12.
You may be right but the argument is not convincing when you appear to be solving for a situation that wasn't suggested. It seems like your just throwing numbers around in a broad sweeping dismissal.
For example, after looking at the image you said: "In that image the heat pump and the heat engine share both the same hot reservoir and the same cold reservoir. Everything in my posts 5 and 8 applies"
In #5 you begin by saying: "Assuming that the cold reservoir is a typical 300 K temperature,..."
In 8 you say: "An ideal COP 10 heat pump with a cold reservoir at 300 K could only raise heat to a hot reservoir of 333 K."
It is rather difficult for me to relate this to a scenario that has to do with a heat engine running on ambient heat. The numbers describe a situation that is the opposite of what was being proposed.
You say: "then for 70% efficiency the minimum hot reservoir temperature would be 1000 K."
We need to agree on what these percentages actually represent. Your interpreting the percentages in terms of Carnot efficiency it seems, which was not the intention. Your taking it too literally. The diagram was not intended to be technically accurate just suggestive as originally presented to a lay audience not a scientific community.
Carnot efficiency is on a scale of absolute zero. The percentages on the chart are only meant to represent energy flow. Like if I fill my bathtub to the top it is 100% full. How then can I distribute that 100% for various necessary purposes. The percentages are not intended to plum the depths of the ocean, which by comparison, that is what using Carnot efficiency amounts to.
It seems Low-Q got the answer he was looking for. He started this thread however by quoting me and posting a diagram I drew. Perhaps its redundant and unnecessary at this point, but if anyone thinks it might be worth the bother I wouldn't mind going back and doing some kind of analysis of what was actually proposed in the materials utilized, and maybe put some real numbers on it. Perhaps the conclusion will be the same. i.e. it can't possibly work, but at least the proof would be valid for the actual proposal rather than one turned upside down.
  • #63
In which case you should carry on the process I have been advocating all along.
Using real world data.
Here is an extract from the manufacturers measured and confirmed capabilities of currently available heat pumps, I could buy off the shelf.
Note that the COP values are realistic not pipe dreams.
  • #64
Your response to my post:
Low-Q said:
Good point. However I am not searching for loopholes in science, just searching for an energysource in the air which a heat pump can harvest in order to power a heat engine. As many links, explanations from you guys has shown, it will not be possible.
This is the crucial misaprension of the thread. There is not an energy source in the air that you can harvest. Afaik, in accepted terminology, you can 'harvest' energy from an energy 'resource' where it is available in some form of chemical, gravitational, thermal, etc. form. Just shuffling the internal energy of a body of air (using an input of energy from some resource) in order to create a temperature difference and then using a heat engine is a pretty pointless exercise. Of course, you can 'power a heat engine' this way but why not use the original energy resource and cut out the (always lossy) middle man? You won't get any more out of the system - as has been ascertained several times.
Is there anything more to the main question of this thread?
  • #65
Around 3. What is the application being analyzed ? Heating a home ?
What does COP actually represent ?
What, from that chart is relevant to the proposal ?
I have no problem with real world data if it is applicable or is somehow relateable to what was proposed but I think the subject needs to be broadened somewhat beyond Heat Pumps and COP. Basically a "heat pump" is the same thing as a refrigerator, a freezer, an air conditioner,... There are many methods for cooling.
In a simple chart it is impossible to do more than be suggestive, so Heat Pump - COP, relatively understandable at a glance but only one possibility.
I has originally sent a PM to Low-Q suggesting that he might want to read Tesla's original paper on the subject crudely represented by the diagram but he didn't have time and as far as I know still has not read it.
Tesla's method of cooling was put forward simply as "By some means or another". Heat Pumps did not exist at the time. As I say, the diagram was only intended to be suggestive not technically accurate.
I think it might be best to make sure we have a clear idea what the intent was. Then it night be possible to consider what the options might be suggested by "Some means or another".
I know what the abbreviation COP stands for but really only a vague idea what it actually means. My impression is that it is very application dependent. How well does the appliance satisfy the requirements. The COP of a vapor-compression unit could be practically doubled if it is utilized for both heating and cooling rather than just one or the other.
If the kids turn up the thermostat the COP is reduced. etc. etc. It seems a rather wild variable to me and somewhat difficult to pin down. Neither am I an HVAC technician.
  • #66
Hey guys, let's be real, were fighting thin air here.I can agree to Low-Q that even with all the academic books and all the knowledge we already have we need to stay open minded , but for someone to be really open minded he needs to know the facts and figures that were made before him because without that basic understanding of physics this new generation is starting to play with magnets and thinking of the so called "free energy" basically a misconception from those who either don't know what their doing or the ones who just enjoy a good laugh when their free energy ideas are being realized by people who thought that the Earth is flat until yesterday.
@Tom without getting into any numbers why don't we talk about the basic concept itself as I believe that all ideas first start off with a thought or concept which is then later if considered realistic , calculated and built if possible.
So by concept , you say that yourself that a heat pump is nothing more than a refrigerator, and that's right well as we know for the fridge to be able to function it needs two things a as good as possible thermal isolation and a energy source to run the pump which then in turn will start to move the liquid that will move the heat from A to B.
So if you ask me I just don't see a way how you could make a heat pump which heats your house already,+ requires a external energy source that moves the heat in and out ,, yet make a electricity generator no matter what you add to the device would it be a heat engine or what not.
To create the heat difference you had to use energy in the first place and now when you have done it you want to get that energy back by dong something further with that moved heat but it just won't do as all devices are lossy and you can never get back as much as you used in the first place.And this basic rule applies to pretty much everything in and around us.
Like I said in my earlier posts you have to have a really huge temperature difference for you to be able to use that and extract considerable amounts of power out of it, just like you have to have a really big water height and displacement difference for a hydropowerstation to get you a considerable amount of energy out of that water, no wonder why they try to build dams on either huge rivers with lots of water flow or between canions which have a huge height and also huge potential difference that will be used to power the turbines.With heat it just isn't the same thing because there aren't such a noticable difference and to create one requires energy. So aren't we just playing with magnets and saying that they don't make "free energy" but then turning them around to hope that something will change?...
  • #67
Exactly.
I have tried to show you, by direct calculation, that the COP and efficiency refer to different ratios, and are not just inverses.
In fact there are two different measures and definitions of COP one for refrigerators and one for heat pumps, which are thermodynamically different.
In a refrigerator we extract as much heat as possible for a given amount of work from the evaporator.
In heat pump we want to maximise the heat obtained from the condenser for a given amount of work.
This leads to different values of Q being used from different points in the cycle to define their COP = Q/W.
This is the last time I will attempt to introduce some reality and reason into this thread.
If you are truly concerned to understand more about the thermodynamics of refrigeration and heat pump cycles read chapter 13 of the book that has been the engineering standard for many years
Engineering Thermodynamics, Work and Heat Transfer by Rogers & Mayhew.
  • #68
That is a reasonable objection. Rather than getting a specific set of numbers to exactly match, we can solve for the general system and just leave it in terms of variables that you can plug in.
Using the same notation as in post 14, the efficiency of an ideal heat engine is again:
[tex]\frac{W_E}{Q_{HE}}=1-\frac{T_{CE}}{T_{HE}}[/tex]
The COP of an ideal heat pump used in heating mode is:
[tex]\frac{Q_{CP}+W_P}{W_P}=\frac{T_{HP}}{T_{HP}-T_{CP}}[/tex]
Because they share both reservoirs we have [itex]T_{CE}=T_{CP}[/itex] and [itex]T_{HE}=T_{HP}[/itex], and to keep the cold side from heating up we need [itex]Q_{CP}=Q_{HE}-W_E[/itex]. Plugging all of these in and simplifying we obtain:
[tex]W_E=W_P[/tex]
In other words, assuming a perfectly ideal heat engine and a perfectly ideal heat pump the heat pump requires all of the work that the heat engine outputs. It doesn't matter what temperatures you use for your input and output sides, they all cancel out and all of the work from the engine is used by the heat pump.
Of course, for real engines and pumps it will be even worse. The real engine is not as efficient as the ideal engine, so it will generate less work, and a real heat pump has a lower COP so it will require more work.
  • #69
Good evening Dale,
One matter absent from your analysis is the small matter of heat transfer efficiency into and out of the reservoirs.
Your perfect machine analysis is silent in this respect.
  • #70
Hi Studiot, I believe that you are talking about the rate of transfer to the reservoir, not efficiency. Correct? The transfer is passive, so it doesn't use or generate work, so I don't see where efficiency would come in.
  • #71
No I'm not talking about rate of transfer.
Let us say you want to use the heat pump to heat a room, obtaining the heat from the outside atmosphere ( a pretty typical practical application).
1)In order to extract heat from the air to your working fluid you have to pass the air over some sort of heat exhanger. Probably you require to expend energy in a fan.
2)Having picked up the heat, you have to pump your working fluid around in heat pump and perform the compression and expansion cycles.
3)You now know what I'm going to say. Having pumped your hot fluid into the room you need a second heat exchanger/fan to remove and distribute the heat.
I was intending to come round to explaining that the manufacturers only quote the the COP of the heat exchanger using (2) as the work budget. This makes advertising headlines but poor engineering.
  • #72
Oh, I didn't realize that. I thought that the COP was for the whole system, which of course includes all of those other fans and parts that you mention for the work.
Well, all that does is reduce the real efficiency further from the ideal efficiency. Since even an ideal heat engine and heat pump could not gain energy this way, what you mention is just one more way for a real system to perform even worse. Worse than 0 is pretty bad.
  • #73
Are you guys discussing heat pumps from the 80's?
I can buy a heat pump with COP of 6.6 @ +7 degrees C when I want to keep an indoor temperature at 20 degrees C. While it is freezing cold outside, -15 degrees C, the COP is 4.3. The heat pump is said to deliver decent heat, when it is -30 degrees C outside, but the factory guarantee down to -25. It is a Mitsubishi Electric heat pump I have been reading about.
Vidar
  • #74
No, we are talking about ideal heat pumps. An ideal heat pump at those temperatures would have a COP of 22.6.
The ideal would be 8.4.
We are giving the idea the complete "benefit of the doubt" and talking about using theoretically perfect heat pumps. And even then it takes all of the work from the ideal heat engine to run the ideal heat pump.
  • #75
I'm sorry but personally I think these kinds of calculations are a waste of time and entirely meaningless, irrelevant, misleading and frankly ridiculous.
As I said before, your using Carnot efficiency on a scale of absolute zero. Its nonsensical.
We are talking about an engine running on ambient heat. "Free" heat all around us in the air. A virtually unlimited supply that is renewed on a daily basis by the sun and will never run out until the sun itself burns out.
Lets take a "real world" example. Not really "REAL" just using real numbers in a hypothetical situation.
Lets say I build an experimental engine that runs on hot air and it works.
I set up hot air solar panels to help concentrate the heat for the engine. I even set up a heat pump along with the solar panels to add more heat on cloudy days.
The engine takes off. It draws in hot air and blows out cold air and generates electricity. I even set up duct work to use the cold air from the engine to air condition my house.
Day after day goes by and it keeps running day and night. I notice that the heat pump is redundant as it never goes on. It wasn't needed.
I'm sitting pretty. All the free energy I can use.
One day the wind blows my solar collector over. I didn't even notice because the engine kept running just the same without it. Still producing electricity. But now the air conditioning is way too cold.
Earlier I measured the heat in the solar panels at an average of 200 degrees Fahrenheit.
The engine was always utilizing 100% of all the heat the solar panels could produce and sometimes then some. Exhausting cold air into the house at a comfortable 60 degree Fahrenheit, even on balmy summer days.
Now with the solar panels destroyed I take new measurements. The engine is now drawing in 60 degree Fahrenheit ambient air directly. I'm shocked to see that the exhaust is now negative 30 degrees Fahrenheit. Thirty degrees below zero! No wonder the house was getting so damn cold.
What is the theoretical "Carnot Efficiency" of this little miracle engine ?
Unfortunately, I know, the thing didn't cool the air all the way down to absolute zero and the whole apparatus didn't disappear reducing itself to a single Bose-Einstein Condensate particle in the process so it can't be 100% efficient at removing every last drop of heat so that the exhaust air was colder than the dark side of the moon or deep interstellar space.
I'm a little fuzzy on the math and the conversion between Fahrenheit and Kelvin and all that technical stuff.
Based on the data. The "Th" and "Tc". all that complicated math stuff that's all Greek to me anyway.
What's the Carnot efficiency of this engine before and after the destruction of my solar collector ?
  • #76
The calculations are a correct analysis of the scenario. The fact that you don't like the answer doesn't make a bit of difference.
Then please post a scientific reference that says that you can use another temperature scale for these equations.
The thing is that heat engines don't run on heat. They run on differences in heat.
So I gathered.
  • #77
So I gathered.
How about just showing the numbers. You've probably already worked it out in your head.
  • #78
Not totally without justification the heat pump manufacturer will say that he does not (necessarily) manufacture the distribution parts.
An air to water system produces water at a stated temp and COP. What you do with it is then your business.
Further comments.
To transfer heat from the ouside air to the heat pump fluid requires the cold reservoir in the heat exchanger to be be colder than the outside air.
To produce warm air at 20°C require the hot reservoir in the indoor heat exchanger to be warmer than 20°C
Thus neither of these figures can be used for COP calculations.
When making comparisons it should be noted in most cases the work input is performed by electricity.
This is more expensive per joule than some other forms of heating.
So the heat output that derived from the work input will be at higher cost.
  • #79
I like the answers fine. If it's understood what it means. most people don't so its misleading.
It isn't the scale. It's that actual utilization of supplied heat to such a heat engine in practical terms. The 100% of all the heat collected by the solar panels for example is something different from ALL THE HEAT down to absolute zero.
Carnot efficiency does not describe practical utilization of the supplied heat, it describes how much of all the heat. ALL of it. That means if you are talking about a hot air engine running on heat in the air, the engine has to cool the air to absolute zero to be 100% "efficient". The engine could be working great making all the energy anyone could ever need but the Carnot efficiency numbers would make it look like a dog. A waste of time.
We can debate that issue another time. I don't exactly disagree. Let's just say this engine, based on Tesla's concept can evolve its own temperature difference. an ingenious combined heat engine slash cooling system. Let's not worry about the working principle, let's just see some numbers.
  • #80
It is not too unlike this little combined heat engine and cooling system, just scaled up a bit. Different kind of heat engine. Different kind of cooling method.
There is no temperature difference until the engine is started, afterwards it maintains its own temperature difference.
This little bird is a heat engine running on ambient heat and evaporative cooling. Evaporative cooling is also driven by ambient heat. So energy from ambient heat in the air is being utilized to produce both energy output and supply cooling.
Until the engine starts, everything is the same temperature.
This is a little different, yet similar.
Still running on ambient heat and simple evaporative cooling from a damp piece of paper.
  • #81
A device that uses a heat pump to create a temperature difference to drive a heat engine, achieving a positive energy output is a violation of the 2nd law of thermodynamics: a type 2 perpetual motion machine. We don't do perpetual motion machines here. Thread locked.
  • · Replies 19 ·
  • · Replies 30 ·
  • · Replies 20 ·
