Stopping discharging a battery during charging
  • Thread starter Thread starter adilsyyed
    Battery Charging
The discussion revolves around the design of a circuit that allows a light source powered by a lead acid battery to remain on during power outages while automatically turning off when the battery is charging. The focus is on the technical arrangement needed to achieve this functionality, including the use of relays.
  • One participant describes the need for a circuit that disengages the light when the charger is active, allowing the light to remain on during power outages.
  • Another participant suggests using a relay powered from the wall power to create different configurations for the light and charging circuit.
  • A later reply emphasizes the importance of using a "break-before-make" type of relay for the proposed solution.
  • One participant expresses a lack of expertise in electronics but appreciates the suggestion and intends to learn more about relays.
Participants generally agree on the use of a relay as a potential solution, but there is no consensus on the specific implementation details or the overall effectiveness of the proposed approach.
Participants have not provided detailed specifications for the relay or the circuit design, and there may be assumptions about the electrical characteristics of the components involved that are not explicitly stated.
adilsyyed
I am from a country where power outage is very common.
I have a light source which is run by a lead acid battery. At night, I want to keep this light ON during power outage and when the electricity is back on, the charging circuit engages and the lights should turn off itself.
I am guessing an arrangement would be needed so that when the charging starts, with it somehow, a circuit should sense it and open/dis-engage the discharging circuit.
Simple Version:
I want to plug the charger in the battery, during power outage the light will be ON and with power on (when the charger starts charging the battery), the light turns OFF.
Simple Version:
I would use a relay powered from the wall power. You can connect your light and charging circuit to different parts of the relay to give the two different configurations.
ummm... That would be a nice way to do it.
Be sure to use a "break-before-make" type of relay. :smile:
If only I was expert in electronics.
But thanks for the head start, that's how we learn. I am going to read more about the relay you proposed.
