What exactly is the reactive centrifugal force (split)
The discussion revolves around the concept of reactive centrifugal force, particularly in the context of rotating reference frames and the application of Newton's third law. Participants explore the definitions and implications of centrifugal and centripetal forces, as well as the interactions between astronauts and the space station.
  • Some participants argue that the term "centrifugal force" is valid when considering forces that point outward from the center of rotation, while others contend that it is misleading and should be associated with centripetal forces instead.
  • One participant claims that the only force acting on astronauts is the centripetal force provided by the space station, while the forces they exert on each other create tensions within the station.
  • Another participant challenges the application of Newton's third law, stating that there is no direct interaction between astronauts, thus no action-reaction force pairs acting on both.
  • Some participants emphasize that the direction of the force applied by an astronaut is centripetal, as it causes acceleration toward the center of the space station.
  • There is a discussion about whether the reaction forces of moons orbiting a planet can be considered centrifugal, with differing opinions on the validity of such examples.
  • One participant asserts that the term "centrifugal" does not relate to causing acceleration, but rather describes the direction of the force itself.
  • Another participant expresses confusion over the distinction between interaction forces and inertial forces, suggesting that both concepts should be clearly differentiated.
  • There is a debate over the interpretation of Newton's third law, with some participants focusing on equal and opposite forces while others emphasize changes in momentum.
Participants do not reach consensus on the definitions and implications of centrifugal and centripetal forces, as well as the application of Newton's third law. Multiple competing views remain, and the discussion is unresolved.
Some limitations include the dependence on specific reference frames and the potential confusion arising from the terminology used to describe forces in rotational dynamics.
  • #121
DaleSpam said:
So if you have trouble understanding shear waves we can do compression waves.
I really think this is overkill.
If you want a scenario where the centrifugal reaction causes centrifugal acceleration in the rotating frame, then take a turntable where a mass on rollers pushes a sliding mass outwards .
If you want a scenario where the centrifugal reaction causes centrifugal acceleration in the inertial frame, then take the rocket on a circular path.
Of course, none of this is really important, because Newton's 3rd applies regardless of acceleration.
  • #122
Andrew Mason said:
Well, I was assuming you were talking about a stress that is the result of two opposing forces that act on the same body in a way that tends to shear - make parts of the body that are close together move in opposite directions. Not sure how that applies here so if I am missing something, feel free to enlighten me.
You are correct, the forces in question are the forces from the bolts and the force from the astronaut's feet. Those forces are in opposite directions and cause the shear stress in the floor. As you correctly indicate, parts of the floor which are close together tend to move in opposite directions, the part closer to the feet tends to move out while the part closer to the bolts tends to move in. This is shear stress.
When the bolts are cut the shear stress in the floor next to the bolts is relieved, but not in the rest of the floor. A shear wave ripples through the material at the speed of sound in the material relieving the shear stress as it goes. Until the shear wave reaches it, the material is in the same state of stress as it was before the bolts were cut.
I can go into more detail if you like, but A.T. is right, none of it is important. The centrifugal reaction force depends on the point of application of Newton's 3rd law, not any acceleration. You can argue with me and A.T. if you like, but even if you do convince us that it is bad terminology, that wouldn't make the bad terminology go away.
  • #123
But that is a perfect example of the fictitious centrifugal force, not the reaction to the centripetal force on the mass. This confusion is the real problem.
That is an interesting scenario but I don't think that the force on the rocket qualfies as a centripetal force.
Centripetal force on a body defined as is dp/dt of the body where dL/dt of the body = 0. But if dL/dt for the rocket + fuel = 0 the rocket would have to constantly be increasing its rotational speed because it is constantly losing mass.
This is correct. And in an inertial frame where dL/dt = 0, all dp/dt is centripetal.
AM
  • #124
Yes, confusing fictitious and real forces is your real problem. In my scenario the sliding block can be very light and have large friction, which by far outweighs the sliding block's fictitious centrifugal force. What moves the sliding block outwards is the real centrifugal force from the inner heavier low friction block.
Based on your criteria most names would apply only to the simple idealized cases, that are found at the begin of a book chapter, where the name is first introduced. Most people who have some abstraction skill prefer more generally applicable names.
That is just the simplest possible case, not the general case.
Fine, if it makes you happy let the speed increase. Or replace the rocket with a plane, flying in a circle. It accelerates air centrifugally, to have a centripetal force.
  • #125
Or you can simply reduce the thrust in proportion to the reduction of mass. I do like the airplane idea also.
  • #126
A.T. said:
... or replace the rocket with a plane, flying in a circle. It accelerates air centrifugally, to have a centripetal force.
In the case of a rocket or aircraft, aren't both the centripetal and centrifugal forces "reaction" forces? For the aircraft, the centripetal force is the reaction (or coexistance) to the air being accelerated outwards, and the centrifugal force is the reaction (or coexistance) to the aircraft being accelerated inwards.
  • #127
rcgldr said:
In the case of a rocket or aircraft, aren't both the centripetal and centrifugal forces "reaction" forces? For the aircraft, the centripetal force is the reaction to the air being accelerated outwards, and the centrifugal force is the reaction to the aircraft being accelerated inwards.
The "action/reaction" label is meaningless. It just indicates that it is a 3rd law force pair.
  • #128
What moves the block outward is inertia. The inability of the friction force between the turntable and the block to provide the centripetal acceleration required to keep both blocks on the turntable, results in the blocks not accelerating sufficiently to stay on the turntable. There is no outward force.
It is the only case in which the force is centripetal - that is constantly directed toward the same inertial point. If dL/dt ≠ 0 the force is not centripetal - it has centripetal and tangential components so it is not pointing toward the same central point.
AM
  • #129
That was my original idea, but Andrew wants L = const. So let's speed up to compensate for mass reduction.
The same in space would be a ship with a solar sail, doing small circles at constant distance to the sun. The radial lift component cancels gravity. The other component provides centripetal acceleration. The reaction to the centripetal force accelerates particles centrifugally.
  • #130
That's mumbo jumbo. You have to use forces acting on the outer block to explain the outer block's outwards acceleration in the rotating frame. There is a fictions centrifugal force acting on the outer block in the rotating frame, but it is not sufficient to overcome friction. Only because of the real centrifugal force from the inner block the outer block accelerates outwards in the rotating frame.
There are even two in the rotating frame.
So there is a centripetal component, and a centrifugal reaction component.
  • #131
I assume the sail reflects the particles back towards the sun, so the sail exerts a centripetal force (and acceleration) onto the particles (in addition to gravity) and the particles exert a reactive centrifugal force onto the sail.
  • #132
rcgldr said:
Wouldn't the sail be reflecting the particles back towards the sun?
The ship makes small circles in a plane that is perpendicular to the solar wind and gravity. The sail is at an 45° angle outwards to the solar wind and gravity. The particles are diverted by 90° and fly off centrifugally within the plane of the circular path.
  • #133
For a rocket and its exhaust dL/dt=0 regardless of how fast or slow or in which direction you point the exhaust. It is a great example for that reason.
  • #134
OK, but even if the particles are diverted 90°, the direction of acceleration of those particles includes a component towards the sun (radial outwards velocity is reduced to zero), and a tangental component (at that instant in time).
  • #135
If I understand him correctly he wants L = const for the body on which the centripetal force is exerted, which is the rocket and the remaining fuel. But the example can be adjusted to work either way.
  • #136
That is not relevant of the circular motion. In the plane of the circle there is a centripetal force and a centrifugal reaction, which accelerates the particles outwards.
  • #137
In order to accelerate the particles outwards, it seems the solar ship would have to travel faster than orbital speed (v^2 > G M / r) in a circular path so that a centripetal force (in addition to gravity) would be required to maintain the circular path, and use some sort of collector and accelerator, which could be an idealized sail, in order to end up accelerating particles outwards.
  • #138
Yuck, that makes it messy. With this definition you need a tangential thrust in order to have centripetal motion. I don't see any reason for that definition.
  • #139
Are you talking about real forces or forces that appear in the non-interial reference frame of the rotating turntable?
If you are talking about real forces, the turntable is trying to grab the outer block and change its velocity. The surface of the turntable is accelerating inward underneath the block. If the friction between the outer block and turntable is not enough to provide the force needed to accelerate both blocks to keep them on the turntable, the turntable surface accelerates away from blocks which continue their inertial motion. They would be accelerated somewhat by the kinetic friction force between the turntable and block until they left the surface.
The only real force that is apparently outward is the reaction force of the block on the turntable. If the turntable and spindle was sitting on a frictionless you would be able to see the block and spindle both rotate about a vertical axis through their common centre of mass. The block would exert a force on the turntable that causes the centre of mass of the turntable to rotate about the common centre of mass (which is between the spindle and the block). Since it is fixed to the earth, the reaction force of the block is exerted on the Earth which undergoes a much smaller rotation.
Which means that the force is not radial: r x F ≠ 0
AM
  • #140
And the reaction force of the inner block on the outer. That is a real force, not fictitious, and s required to explain the movement in all frames.
This line of conversation is still irrelevant. Regardless of the validity of your reasons for disliking it, the term exists. You cannot wish it away, nor can you reason it away.
  • #141
You can call it what you like. It is due to inertia and it does not accelerate anything away from the centre of rotation.
AM
  • #142
Andrew Mason said:
It does not accelerate anything away from the centre of rotation.
Whether it does or not is irrelevant to the naming convention.
But in some cases it clearly does.
  • #143
We have beaten this issue to death. So let me recap where I think we differ.
I think we fundamentally disagree on what third law action and reaction pairs are.
It is easy in a collision of free bodies analysed from an inertial reference frame. One body accelerates in one direction and the other accelerates in the opposite direction - changes in momentum are equal and opposite. Or, if a rocket sends rocket gas in one direction, the rocket recoils in the other. These are third law action/reaction pairs. No problem.
The problem occurs when you do not have a system that defines an inertial reference frame.
For example, you say that the reaction to the centripetal force supplied by mechanical means is the force that the body being accelerated applies to the body or part of the body that is supplying the accelerating force. I say that is simply an inertial effect and the real reaction/action pairs are the centripetal force that the rotating body experiences and the centripetal force that this body exerts on the rest of the system as both rotate about their common centre of mass.
Similarly, the third-law pair in applying a force to a box with my hand (with me standing on the earth) is the force I exert in the opposite direction on the earth. The change of momentum of the Earth that results is equal and opposite to the change of momentum of the box. You seem to be saying that it is the force of the box on my hand. I say that force of the box on my hand is simply an inertial effect - a pseudo force really because it can never be associated with an acceleration.
In my view, this is where we disagree. We can argue all we like about Newton's third law but we will continue to disagree because we take somewhat different view on the application of the law to these situations.
AM
  • #144
I agree that this is the fundamental disagreement. However, this is not simply a difference of equally-valid opinions. You wish to state Newton's 3rd law in terms of changes in momentum instead of forces.
1) You have been unable to produce any textbook or online reference which expresses the third law mathematically in terms of momenta, while I have produced several that express it mathematically in terms of forces.
2) You have also been unable to produce any textbook or online reference which even clearly expresses it verbally in terms of momenta.
3) You have been able to find one reference which is, by your own admission, quite unclear so a small part of it can be construed in a way that at least doesn't contradict your position. However, even that reference contradicts your position when you read the whole reference instead of taking that small part out of context.
  • #145
What Newton meant by "Newton's third law" is perfectly clear. First he defines
Principia Definition IV said:
An impressed force is an action exerted upon a body...
In other words, "actions" are "forces".
Principia Law III said:
For every action there is always opposed an equal reaction: ...
The examples following the definition are clearly about forces, not momentum. For the example of a horse drawing a stone tied to a rope, he is talking about the equal and opposite forces the rope exerts on the horse and the stone. By any reasonable interpretation of that scenario, the changes of momentum of the horse and the stone are not equal and opposite, in general.
The explanation of law III continues
If a body impinge upon another, and by its force changes the momentum of the other, the change in momentum of that body will be equal and opposite; that is to say, if the (movement of the) bodies are not hindered by any other impediments.
(My bold).
To summarize, action and reaction forces are always equal and opposite in pairs, but they don't necessarily cause equal and opposite changes of momentum if the motion of the two bodies is constrained in some other way.
That explains why the changes in momentum of the horse and the stone are not equal and opposite, of course.
Reformulating classical mechanics in terms of "Mason's laws of motion" is fine by me, but don't mis-attribute Mason's laws to Newton where they are different.
  • #146
AlephZero said:
What Newton meant by "Newton's third law" is perfectly clear. ...
If it was "perfectly clear" there would be no discussion of how confusing it is, as in this quote that I referred to earlier from a physicist , Mark Hammond:
"Newton’s explanation starts out talking about forces and pressures, speaks of obstructing and advancing “progress,” and finally ends up talking about what appears to be momentum. I’ll say right here that I am unimpressed with the clarity of Newton’s explanation. I go back and forth between thinking action/reaction should be read as the change in motion as opposed to being read as the thing that changes the motion. But rather than pick nits (and criticize an author who can’t defend himself), let’s zero in on what Newton seems most intent upon telling us in this, his third law of motion: there is a specific relationship between the changes in the motions of two interacting objects. Hence, this is a law of motion."​
They do cause equal and opposite changes of momentum if you look at the motions of the body and the rest of the inertial system the body is interacting with. You can always do that.
It is not that the principle of reciprocity of forces between contact points is wrong (it is correct in most cases). But this reciprocity is demonstrated by the changes in momentum that the forces create as measured by the changes in motion of the centres of mass of the two interacting parts of an inertial system. If you want to explain it in terms of the reciprocity of forces, it is explained by the forces as measured by the accelerations of the centres of mass of the interacting parts of an inertial system. It is neither illuminating nor practical to apply Newton's third law in terms of the reciprocity of forces between the contact points. So I have difficulty believing that is what Newton fundamentally intended to convey in the third law.
In the simple situation of an astronaut pushing off from a spaceship with his legs, the third law is demonstrated by the equal and opposite changes of momentum that result to the two parts of this inertial system (ie. astronaut and space ship). If you just apply the reciprocity of forces between the astronaut's feet and the surface of the space station, this does not explain the physics. You have to take into account what the feet and space station surface are connected to. You then have to take into account the masses of those bodies and the motions of the centres of mass of those bodies. Those are legitimate third law action/reaction pairs. They do not lose that quality simply because the centres of mass are not touching. There are a myriad of other forces (between different parts/atoms etc.) that we simply ignore because they are not important.
AM
  • #147
Then find a good reference that supports your interpretation. Otherwise you are simply engaging in personal speculation.
In context, Newton's Principia does not support your approach, and I have yet to see any other scientific reference that does either.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 19 ·
