Heat pump COP theoretical maximum
The discussion revolves around the theoretical maximum of the coefficient of performance (COP) for heat pumps, particularly in the context of heat pumps transferring heat from a colder reservoir to a hotter one. Participants explore thermodynamic principles, calculations, and assumptions related to COP values, with a focus on air-to-air and land-to-air heat pumps.
  • One participant questions the validity of the Wikipedia formula for COP, suggesting it leads to values greater than 2, which they argue violates the second law of thermodynamics.
  • Another participant asserts that a COP greater than 2 is possible if the temperature difference between the reservoirs is not too large, indicating a potential error in the first participant's calculations.
  • Some participants clarify that COP greater than 2 is not feasible for air-to-air heat pumps under certain assumptions about heat loss, while it may be possible for land-to-air systems.
  • There is a discussion about the implications of COP calculations on practical applications, including economic considerations for heating buildings.
  • One participant presents a mathematical derivation of COP, suggesting that there is no fundamental reason it cannot exceed 2, while others challenge this by discussing the implications of infinite COP and its relation to realistic temperature differences.
  • Several participants engage in a back-and-forth regarding the assumptions and definitions used in calculating COP, with some emphasizing the need for accurate measurements under varying conditions.
Participants express differing views on the feasibility of achieving a COP greater than 2 for specific types of heat pumps. The discussion remains unresolved, with multiple competing perspectives on the calculations and assumptions related to COP.
Participants highlight limitations in their calculations and assumptions, particularly regarding temperature differences and the definitions of the reservoirs involved. There is also mention of the need for empirical data to support theoretical claims.
This discussion may be of interest to individuals studying thermodynamics, engineers working with heat pump technologies, and those considering the economic implications of heating systems.
  • #61
I must admit that there was logical mistake in my COP=5 cycle. The heat pump will not pump any more when the cold reservoir is heated(above the ambient) back from hot reservoir. Thanks everybody for explaining patiently.
So there is no other limitation to the COP than COP≤Th/(Th−Tc).
The COP can be very high if temperature dT is very small.
The practical heat pumps COP is so much below the theoretical maximum only because the various constructional problems.
The other interesting question is: theoretically, can we run the heat engine outside the building and use the work from the heat engine to run the heat pump to heat the building from the outside air and get the same amount or more heat, than burning the fuel inside the building with 100% efficiency?
Science news on Phys.org
  • #62
That is exactly how most heat pumps run. The input work is provided by electricity generated by heat engines operating in an outside power plant. As I explained in my earlier post #57, in that case you need a COP of about 3.5 just to break even (ie. to get the same amount of heat than you would from burning the fuel with 100% efficiency). If the COP>3.5 you get more heat than burning the fuel inside at 100% efficiency. And a COP > 3.5 is easily possible. If the temperatures are Th/Tc = 293K/273K, the maximum Carnot COP would be 293/20 ≈ 15
AM
  • #63
I answered this already in post 50.
  • #64
This was supposed to be the case when the heat engine is inside the house, you answered in post 50.
The usual case is the is that heat engine is outside the building (in power plant). I have feeling that when the heat engine in the power plant uses same temperature as outside for cooling then no way we can get more heat with the air to air heat pump to heat the building, than was used at the power plant.
I was out gathering some free energy (firewood) :)
  • #65
I was assuming that the heat engine and the heat pump were both using the outside air as the cold reservoir in both cases. The difference is that the heat engine uses a hot reservoir heated by the fuel and the heat pump uses the inside of the building as the hot reservoir. The equation I provided applies.
  • #66
Thanks!
  • #68
An engineering way to proceed is to try it in practice ;)
Years ago, I deviced LTSPICE models of Peltier thermoelements. Can be found from LTspice yahoo groups: Files > tut > Thermal > tec_fridge.zip.
The TEC allows you to set realistic parameters, and also creating ideal (lossless) models.
Then you should generate a LTSpice model where you have the hot container (capacitor) and a cold container (another capacitor) and a heat pump (TEC) and the electrical power source (e.g. current source).
If you can build a heat pump model (using supplied TEC model, and resistors (R>0) and other passive realistic components) which seems to break laws of thermodynamics, I'll buy you a beer.
BR, -Topi
  • · Replies 19 ·
14K
