Why do bottle jacks see differences in air pressure?
The discussion centers on the phenomenon observed in single-stage bottle jacks regarding air pressure changes. When the filler plug is removed after pumping the jack, a slight pressure difference is noted, attributed to the warming of air inside the cylinder during operation. This pressure increase occurs because bottle jacks operate through hydraulic fluid displacement, and removing the filler plug allows air to escape when the piston is pushed down. The discussion confirms that this effect is temporary and will equalize after a period of cooling.
  • Understanding of hydraulic systems and their operation
  • Familiarity with the mechanics of bottle jacks
  • Basic principles of gas laws and pressure dynamics
  • Knowledge of fluid displacement in hydraulic applications
  • Research the mechanics of hydraulic fluid displacement in bottle jacks
  • Study the effects of temperature on gas pressure using the ideal gas law
  • Explore maintenance techniques for hydraulic jacks to ensure optimal performance
  • Investigate the differences between single-stage and double-stage bottle jacks
This discussion is beneficial for mechanical engineers, hydraulic system technicians, and anyone involved in the maintenance and operation of hydraulic jacks, particularly those seeking to understand the effects of air pressure in hydraulic systems.
Jupiter6
I've noticed if you remove the filler plug on a typical single-stage bottle jack and pump it up and then push the rod back down you can hear air come out of the filler hole. It's a very slight pressure difference but it's there. You can see this by putting your thumb or a piece of scotch tape over the filler hole.
Is this a result of the air warming up inside the cylinder and creating a pressure slightly higher than atmospheric when you pump it?
Bottle jacks are hydraulic- they operate through displacement of fluid volume. If you open the fill hole (and drain the hydraulic fluid inside) it will instead operate using air, although it won't be able to lift as much weight. When you push the rod back down you're just pushing the air back out.
I'm doing this with all the fluid still in the jack. Jacks are filled with fluid to just under the filler hole.
In other words, if you take a brand new bottle jack that's been properly filled and pump it a few times, then remove the filler plug and push the piston down, you'll see and hear a small amount of air come out of the filler hole.
I suppose if you pump the jack, push the piston down and then remove the filler plug 20 minutes later you won't see any change in air pressure since everything has had a chance to cool down and come back into equilibrium.
  • · Replies 45 ·
  • · Replies 27 ·
  • · Replies 20 ·
12K
  • · Replies 39 ·
18K
