Where did I go wrong in my calculations for the inertia dyno?
  • Context: Graduate
  • Thread starter Thread starter madhatter106
    Inertia
The discussion revolves around the calculations related to an inertia dynamometer (dyno) used for testing engine performance. Participants are examining the equations and methodologies employed to derive torque and moment of inertia from engine RPM and dyno data. The focus is on identifying potential errors in calculations and understanding the relationships between various physical quantities involved in the testing process.
  • One participant outlines their calculations for torque and moment of inertia, expressing uncertainty about the results and potential errors in their methodology.
  • Another participant points out that the moment of inertia (MOI) has units of kg*m^2, suggesting that the original calculations may have incorrect units.
  • Some participants propose deriving the drum's moment of inertia from dyno data, emphasizing the need to account for any braking forces that could affect the results.
  • There is a discussion about the formula for the moment of inertia of a hollow cylinder, with one participant asserting that the correct formula involves the sum of the squares of the outer and inner radii, rather than the difference.
  • One participant mentions that they have calculated the MOI as 1008.71 kg*m^2 for the drum, which they believe is accurate based on the drum's mass and dimensions.
  • Another participant raises concerns about the resolution of the RPM data, suggesting that it may contribute to inaccuracies in the torque calculations.
  • There is a mention of a potential misunderstanding regarding the relationship between torque (Nm) and moment of inertia, with one participant questioning if they are conflating different units.
  • Participants discuss the need to verify the calculations and assumptions made regarding the inertia of the drum and the chassis.
Participants express differing views on the accuracy of the calculations and the formulas used. There is no consensus on the source of the discrepancies, and multiple competing perspectives on the correct approach to calculating moment of inertia and torque remain present.
Some limitations include potential errors in unit conversions, assumptions about the absence of braking forces, and the resolution of RPM data affecting the calculations. The discussion also highlights the complexity of accurately modeling the behavior of the inertia dyno based on available data.
This discussion may be of interest to engineers and technicians involved in engine testing, automotive performance analysis, and those working with dynamometers in racing or development contexts.
madhatter106
I'm trying to figure where I've gone wrong in my calcs. the physics of the inertia dyno are simple enough however I can't seem to get the proper results.
[tex]I=1/2*m*(r_{1}^{2}-r_{2}^{2})[/tex]
[tex]\alpha=\frac{d\omega }{dt}[/tex]
[tex]\tau =I*\alpha[/tex]
these are some of the equations I'm using, the torque should be in Nm when [tex]MOI=kg/m^2[/tex]
the information I'm using comes from data sets off the ECU. I'll explain a bit, a test development engine has been run on the dyno using a chassis, the numbers are good. what I was asked is if it's possible to back out and use the ECU information to output similar numbers to the dyno, first blush I figure sure it shouldn't be that difficult, famous last words, right?
I have the rpm vs time data in milliseconds, specifically the rpm is counted every 20 milliseconds, I have the dyno numbers for each recorded run so I can compare results, i.e. the data set for one pull has a recorded ECU run for all sensors, rpm,time, temp etc...
I have the gear ratios for all gears, wheel dia etc..I have put together a spread sheet with the input rpm to the gear box, output for each gear in rpm and mph to the drum roller dynomometer, drum dyno rpm and mph, and delta between them. the rpm on the dyno drum is converted to radians per second.
step 1:
engine rpm to drum rpm (calculated via gear ratios)
step 2:
drum rpm to radians [tex]\omega /sec[/tex]
step 3:
[tex]\alpha =(\omega _{1}-\omega _{2})/(t_{1}-t{2})[/tex]
step 4:
[tex]\tau Nm=I*\alpha[/tex]the numbers are wildly high, the curve looks about right, peaks near the dyno's output. however there are massive spikes due to the time count where the rpm is recorded in whole numbers to the millisecond count so the time moves forward but the rpm holds a bit, on avg it's 60~80 milliseconds per revolution count then it jumps a fair amount in the next step. resolution could be better but it's all I've got to work with.
I'm assuming at this point I've calc'd wrong somewhere but can't seem to figure where. I have the drum mass and radius data for a correct MOI. using the gear reduction I have the drum rpm to engine rpm and assume that should be accurate enough neglecting slip and friction loss.
the reason I'm going to this trouble is the inertia drum mass exceeds the chassis weight by a factor of 2.2, the loads are very high for the final working loads the engine will be under. If I can re-calc the dyno run then I should be able to factor the delta in the dyno's inertia to the chassis inertia and approx the acceleration of the chassis in the real world by using this equation:
[tex]\I =[\frac{Dm-Cm}{Cm}*Dm]+Dm[/tex]
Dm=drum mass
Cm=Chassis mass
Hopefully someone can point out my error, Thanks..
Moment of inertia has units of kg*m^2
As mentioned above, you have the wrong units for your angular moi.
You can derive the drum's moi from your dyno data since you know the output power and how fast the rpms (angular velocity) is changing. But you need to make sure that there are not any other braking forces being applied to the dyno drum during the run which would make your calculations essentially useless.
One other thing to think about: If you know what your power curve looks like from the dyno data, it's fairly easy to apply the data in a simulated run. (I'm assuming your doing this for as part of a racing program.) Remember that power is how fast energy can be delivered to a system and that E = 1/2 m V^2. Just total up the energy delivered and solve for V. (You'll need to add a factor to account for aerodynamic drag.)
You also have another possible problem with the formula for mass moment of inertia of the dynamometer drum.
Assuming the drum is a hollow cylinder, the MOI is given below:
MOI = (m/2)*(Router^2 + Rinner^2)
It's counterintuitive, but accurate
syntax error on my post, the slash shouldn't be there. the drum weighs in at 2950kg, the MOI I've calculated is 1008.71 kg m^2, it's not a solid cylinder or it would be 548.128kg m^2
The runs where done on an inertia drum dyno, no eddy or brake drag at any point, other then frictional drag of the bearings and the rotating engine assy, gearbox etc...
the runs are on avg 7~7.5 secs long, a bit shorter then the 10sec avg. if I avg the angular acceleration over 7.3 sec for example, then I get 7,799 Nm.
let me walk thru a step,
engine rpm to drum rpm:
(3913/4.61)*(25.3/48)
drum rpm to radians per second:
(2*∏*rpm)/60
acceleration:
(ω^2-ω^1)/.02
the .02 being the 20 milliseconds between each point
torque:
MOI*Acceleration
I'm assuming I've goofed a step somewhere...
that's the same MOI I posted isn't ?, the drum is a hollow cylinder. the first equation in my post I=1/2*m*(r_{1}^{2}-r_{2}^{2}
Look carefully at your formula for MOI versus what is in my attachment:
Your formula has the difference of the radii squared. For a hollow cylinder, the MOI is proportional to the sum of the radii squared.
thanks, I need to double check my posts, fortunately the equation in my spread sheet is the sum and not the difference.
the only way I've been able to get similar results to dynomometers output is bytaking the Nm of torque dividing it by 10, seems to be high by that factor then summing time point t1+t2 for t2, then t2+t3 for t3 etc.. it's a bit jittery more then likely due to the resolution on the rpm counts.
I did a calculation est on the overall run time to mass of the drums as the chassis mass, using the delta in time points to velocity I could plot the Tq points. that matched the dyno numbers.
the only thing off with the first calcs seems to be with the Nm tq force. possibly that the MOI is kgf which is not equal to Nm 1:1 ? though MOI of 1kg m^2 = 1 Nm
What are the details of the dyno roller? (mass, dimensions, etc.)
madhatter106 said:
the only thing off with the first calcs seems to be with the Nm to force. possibly that the MOI is kgf which is not equal to Nm 1:1 ? though MOI of 1kg m^2 = 1 Nm
A Nm can be a measure of work or it can be a torque depending on what you're doing. It's -not- a measure of moi.
One kgf will be equal 9.8N.
11K
  • · Replies 20 ·
36K
