Conservation of Angular Momentum of a stick
The discussion revolves around the conservation of angular momentum in a system consisting of a uniform stick and a point particle. Participants explore the implications of a collision between the particle and the stick, considering the angular momentum before and after the collision, and the reference points for calculating angular momentum.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants assert that angular momentum should be conserved in the system, questioning how it can be conserved if the initial angular momentum is zero and becomes non-zero after the collision.
  • Others clarify that a point particle can have angular momentum relative to a reference point, even if it does not rotate, and provide the equation for calculating angular momentum.
  • There is a discussion about the appropriate reference point for calculating angular momentum, with suggestions to use the center of mass of the stick rather than the end where the collision occurs.
  • One participant acknowledges a misunderstanding regarding the calculation of angular momentum and the importance of selecting a reference point.
  • Another participant points out potential confusion in notation, suggesting that different symbols should be used for angular momentum and the length of the stick.
Participants express differing views on the initial conditions of angular momentum and the choice of reference point for calculations. There is no consensus on a single approach, and the discussion remains unresolved regarding the best method for calculating angular momentum in this scenario.
Participants highlight the dependence on reference points for calculating angular momentum, and there are unresolved issues regarding the implications of using different points for this calculation.
pluspolaritons
Here's the scenario:
A uniform stick of length L and mass M lies on a horizontal surface. A point particles of mass m approaches the stick with velocity v on a straight line perpendicular to the stick that intersects with the stick at one end. After the collision, the particle is at rest.
My question is, the angular momentum should be conserved in this system right? After the collision, the stick will gain angular momentum as it will be rotating (as well as translating) after the collision. But initially, the particle could either have or do not have angular momentum depending on whether the particle is rotating. Assuming that the particle does not rotate, then the particle should not have any angular momentum. Then in this case how is the angular momentum conserved? The initial angular momentum would be zero initially and non-zero after the collision right?
"The law of conservation of angular momentum states that when no external torque acts on an object or a closed system of objects." In this case the torque is an internal torque in the particle-stick system right?
Please help thanks.
A particle can't "rotate" because it is considered to have all of its mass located at a single point in space. That's what physicists mean by "particle": a point mass. It is not an extended body.
However, the particle can have angular momentum around a point. Angular momentum is not associated only with the rotation (spin) of extended bodies. It is also associated with the motion of a point particle relative to some reference point. For example, for a system consisting of a planet orbiting a star, there is some angular momentum associated with the orbit of that planet around the star (not just the spin of the planet around its axis). In other words, even if the planet weren't spinning, just orbiting in a circle, the system would still have angular momentum.
For a point particle moving with linear momentum p, the angular momentum L of that particle around some reference point is given by the equation$$\mathbf{L} = \mathbf{r}\times\mathbf{p}$$where r is a position vector going from the reference point to the particle.
So, even if the particle isn't spinning (which it can't), there is still non-zero angular momentum initially.
Please help thanks.
From which point you are calculating the angular momentum, and as well stating its conservation?
Ok thanks!
As the particle moves, the angular momentum of the particle will vary as it moves right? So in this problem we calculate the angular momentum of the stick from the pivot of the stick which is at the end of the stick opposite to where the particle collides with it. So I should also use that pivot as a reference point to calculate the angular momentum of the particle right.
So the initial momentum before collision should be:
L=r x p = L x mv = Lmv.
Correct?
Hi, I think I understood the problem now thanks to cepheid. I was assuming that the angular momentum of the particle is zero at all point without using any reference point.
Ok thanks!
In general, yes, but you can just consider angular momentum at the instant just before the collision, and then again at the instant just after it.
It might be more convenient to use the centre of mass of the stick as your reference point, since, after the collision, all of the angular momentum of the system will be due to the rotation of the stick around its centre of mass, so it makes sense to consider conservation of angular momentum around that point.
Correct?
I think you're using the letter 'L' for two different things here: the angular momentum, and the length of the stick. So that's confusing. Maybe use a different letter for the length of the stick, like ##\ell##. But basically this is correct, except there will be a slight change in the magnitude of r because of my comment above about using the centre of mass as the reference point. So the distance won't be ##\ell##, but it will be related to ##\ell##.
It might be more convenient to use the centre of mass of the stick as your reference point, since, after the collision, all of the angular momentum of the system will be due to the rotation of the stick around its centre of mass, so it make sense to consider conservation of angular momentum around that point.
Oh right, I was thinking the pivot is at the end of the stick. Ok you're right, the pivot should be at the center of mass.
Good catch, I didn't notice I was using 'L' for two different things. Thanks for pointing that out.
Thanks again!
If you consider the end of the stick where the collision occurs, in this point the resultant torque is 0. This is because all forces pass trough this point. So there is conservation of angular momentum in this point. The initial velocity of the ball also passes trough this point, so the angular momentum is zero. After the collision the stick gets a both translational and rotational motion. The velocity of the translational motion can be calculated by the conservation of linear momentum. Then we decompose the two motions and we sum vectorially the angular momentum of each one. Note the translational angular momentum will be negative (if we consider the positive axis going out the page). The rotational angular momentum will be positive. If we sum both and equal 0, we find the angular velocity. If I didn't missed anything w=mv/6ML, where w=angular velocity, v=initial velocity of the ball, m = mass of the ball, M = mass of the stick
Try to calculate by yourself and see if you get the same answer
What about rotational angular momentum, e.g a disc that is rotating. Does the angular momentum depends on where my point of reference is?
Yes. The fact is: L = Iω for a rigid body spinning around an axis, where I is the moment of inertia of the body around that axis. I think that if you start with the definition of angular momentum I gave before, you can show that you get the same answer independently of what reference point you choose.
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 36 ·
17K
