Continuity equation, partial derivative and differential operators
The discussion centers on the continuity equation and the application of partial derivatives and differential operators in fluid dynamics. The equation presented, -∇(ρv)=∂/∂t(ρdτ), where dτ=Adx, illustrates the relationship between density (ρ), velocity (v), and mass flux. Participants express confusion regarding the mathematical transitions between the lines, particularly the implications of ρ being constant versus variable, and the distinction between gradient and divergence operations. Clarification is sought on the definitions of the symbols and their dependencies on time and space.
  • Understanding of fluid dynamics principles, specifically the continuity equation.
  • Familiarity with vector calculus, including gradient and divergence operations.
  • Knowledge of partial derivatives and their applications in physics.
  • Basic concepts of mass flux and density in fluid systems.
  • Study the derivation and implications of the continuity equation in fluid dynamics.
  • Learn about vector calculus operations, focusing on gradient and divergence.
  • Explore the relationship between density, velocity, and mass flux in various fluid scenarios.
  • Investigate the role of time and space dependencies in fluid equations.
Students and educators in physics or engineering, particularly those teaching or learning about fluid dynamics and mathematical modeling of physical systems.
pisgirl
Hi all!
I have the following slide, and whilst I understand that the original point is "the rate of density, ρ, in each volume element is equal to the mass flux"...i am totally lost on the mathematics! (And I am meant to be teaching this tomorrow). I do not have any information on what the indivudual symbols refer to, I guess A is area and t is time etc. Can anyone understand this:
-∇(ρv)=[itex]\frac{\partial}{\partial t}[/itex](ρd[itex]\tau[/itex]) where d[itex]\tau[/itex]=Adx
-∇.v = [itex]\frac{\partial}{\partial t}[/itex] (Adx)
-[itex]\frac{\partial v}{\partial x}[/itex] Adx = [itex]\frac{\partial}{\partial t}[/itex](Adx)
-[itex]\frac{\partial v}{\partial x}[/itex]=[itex]\frac{1}{A}[/itex] [itex]\frac{\partial A}{\partial T}[/itex]
Unfortunately I am not sure how to even get from line 1 to 2
and how t combine partial with full!
Argh! Thank you in advance!
Welcome to PF, pisgirl! :smile:
pisgirl said:
Hi all!
I also have difficulty to make sense of these formulas.
I think you can only get from line 1 to line 2 if ρ is independent from both time and location.
Then ρ can be moved outside the differentiation and get canceled.
But I presume ρ is not supposed to be constant?
Would it be dependent on time?
Can you indicate which quantities are supposed to be vectors and which scalar?
And which quantities depend on place and/or time?
Line 2 contains ∇.v making it ambiguous what v represents.
What does it represent?
Volume? Velocity? Specific volume?
Note the difference between ∇v and ∇.v.
The first is a gradient which requires a scalar function and yields a vector.
The second is the divergence which requires a vector function and yields a scalar.
In line 3 we see that it was either
##∇v = (\frac{dv}{dx}, \frac{dv}{dy}, \frac{dv}{dz})##, but where did the other components go then? And where did Adx come from?
##∇ \cdot \mathbf v=\frac{dv_x}{dx} + \frac{dv_y}{dy} + \frac{dv_z}{dz}##.
If we assume ##v_y = v_z = 0##, we're still left with an Adx that comes out of nowhere.
In line 4 suddenly a T pops up.
Temperature?
Or a typo that should have been ##\tau##?
