How Do You Convert Old English Length Measures to Modern Units?
  • Thread starter Thread starter AtlBraves
The conversion of old English length measures to modern units involves understanding the relationships between units such as gry, line, inch, and point. A gry is defined as 1/10 of a line, with a line being 1/12 of an inch, leading to the conclusion that 1 gry equals 1/120 of an inch. Additionally, the area conversion from gry squared to points squared requires careful unit cancellation, resulting in a conversion factor of 6/5 gry per inch. For gold measurements, the density of gold (19.32 g/cm³) is crucial for calculating the area of a leaf and the length of a fiber when given mass and dimensions.
  • Understanding of old English length measures, specifically gry and line
  • Knowledge of modern length units, including inches and points
  • Familiarity with unit conversion techniques and dimensional analysis
  • Basic principles of density and volume calculations for materials like gold
  • Research the historical context and usage of old English measures in various fields
  • Learn about dimensional analysis and unit conversion in physics and engineering
  • Explore the properties of gold, including its density and applications in manufacturing
  • Study the mathematical principles behind area and volume calculations for different shapes
Mathematicians, historians, educators, and anyone involved in fields requiring precise unit conversions and measurements, particularly in historical contexts or materials science.
AtlBraves
I know these questions are simple, but for some reason I can not seem to find the right answers.
1. [HRW7 1.P.002.] A "gry" is an old English measure for length, defined as 1/10 of a line, where "line" is another old English measure for length, defined as 1/12 inch. A common measure for length in the publishing business is a "point", defined as 1/72 inch. What is an area of 0.75 gry^2 in terms of points squared (points^2)?
6. [HRW7 1.P.020.] Gold, which has a mass of 19.32 g for each cubic centimeter of volume, is the most ductile metal and can be pressed into a thin leaf or drawn out into a long fiber.
(a) If a sample of gold, with a mass of 66.31 g, is pressed into a leaf of 4.800 µm thickness, what is the area of the leaf?
(b) If, instead, the gold is drawn out into a cylindrical fiber of radius 1.000 µm, what is the length of the fiber?
For the first one I find a gry to be 1/120 inch. To convert I do .75 gry^2 * (0.6 points^2/1 gry^2) = .45 points^2
Apparently this is wrong.
For the second one I get 7.15 m for (a).
I have no idea how you got that a "gry" is 1/120 of an inch.
Saying that a gry is 1/10 of a line is the same as saying that there is 1/10 "gry per line" which we can represent as (1/10) (gry/line).
Saying that there is 1/12 in in a line is the same as saying that there is 1/12 "inch per line" or (1/12)(in/line).
To get the relationship between grys and inches, we need to "cancel" the "line" in the fractions. If we MULTIPLY the fractions, we get 1/120 (aha! that's what you did!) but the units would be "inch-gry/line<sup>2</sup>", not what we want. If we DIVIDE (1/10 gry/line) by (1/12 in/line), that is the same as multiplying (1/10 gry/line) by (12/1 line/in) which is 12/10 gry/in. There are 12/10= 6/5 gry per inch. (I thought it would be peculiar for the "Olde English" to NEED a unit that small!)
Okay, there 1/72 in in a point (72 points in an inch) or 1/72 in/point. How many points are there in a gry? (You want "X points/gry". Be careful how you set up the fractions!) Once you've got that "square points/square gry" should be easy.
For 6a, "7.15 m" can't possibly be right! You are asked for "area"- your answer must be in m<sup>2</sup> or "square meters", not meters.
You know there are 19.32 g/cm<sup>3</sup> for gold and you have 66.31 g of gold. Look at the "fractions". What do you need to do to get rid of the grams (g) and get the result in "cm<sup>3</sup>"?
Once you have that, you also know "1.000 \[\mu\]m" (How many cm is that?), How do you combine "cm<sup>3</sup>" and "cm" to get "cm<sup>2</sup>?
Is that the case? I take it to mean that there is 10 gry per line, in the same sense that when we say an inch is 1/12 of a foot it's the same as saying there are "12 inches per foot."
I also come up with 1 inch = 120 gry:
1 gry = 1/10 line
10 gry = 1 line
1 line = 1/12 inch
12 line = 1 inch
1 inch X (12 line/1 inch) X (10 gry/1 line) = 120 gry
Mark
  • · Replies 19 ·
20K
