Here's an easy riddle: You are in a room with 3 switches.
  • Thread starter Thread starter Icebreaker
    Riddle Switches
The discussion revolves around a riddle involving three switches and three lightbulbs, where participants explore various methods to determine which switch controls which bulb. The scope includes problem-solving strategies and reasoning related to the riddle.
  • One participant suggests using a mirror to see into the other room and proposes a long wait to identify the bulbs based on their state.
  • Another participant offers a method involving turning on two switches and then checking the temperature of the bulbs to identify which switch controls which bulb.
  • A different approach involves using weights to turn off a switch after a delay, allowing for identification based on which bulb turns off.
  • Some participants discuss the feasibility of extending the method to more than three bulbs, raising questions about the sensitivity of touch to temperature differences.
  • One participant mentions the cooling rate of bulbs and proposes an experimental approach to determine how long to wait before checking the bulbs.
  • Another participant recalls solving the riddle in seventh grade and expresses curiosity about how another user would approach it without touching the bulbs.
  • Several participants reference the historical context of lightbulbs and their characteristics, suggesting that older bulbs may provide different clues based on their physical condition.
Participants present multiple competing views and methods for solving the riddle, with no consensus reached on a single solution. There is also discussion about the limitations of the proposed methods.
Some assumptions about the physical properties of the bulbs, such as their mounting height and cooling rates, are not universally agreed upon. The discussion includes various hypothetical scenarios that may affect the outcomes.
Icebreaker
You are in a room with 3 switches. The room is adjacent to another in which there are 3 lightbulbs. Each of the lightbulbs is connected to a switch in your room. You cannot see into the other room. You may manipulate the switches in any way you like, and you may go to the other room and observe the results, but only once (once you leave your room, you cannot reenter).
How do you find out which switch leads to which bulb?
Ooh, I love this problem! :biggrin:
Hmmm...
  1. Place a mirror in the doorway, so that you can see into the other room.
  2. Shout to your friend in the other room, "I'm working the first switch now!", etc.
  3. Switch on #1, and wait for 20 years. Now switch on #2. Go into the other room. Bulb #1 is blackened (and burnt out). Bulb #2 is on. Bulb #3 isn't.
There is a less destructive way to do this.
have one on, one off, one on, tape a weight above one on light switch so it'll eventually fall off and turn it off, and run over to the other room to see which one turns off =)
Answer You turn two of the swtiches on and leave one off. Then after a minute or so you turn off on of the switches that is on. Enter the room and you can see immediately which on leads to the one switch. Then touch the other lightbulbs, which is off, and see which is hot. The one that is hot is controlled by the switch that was turned on and then switched off after a minute or so before entering the room. This then leaves one switch with one lightbulb. Easy. [/color]
The Bob (2004 ©)
I was assuming that the light bulbs were mounted up on the ceiling, out of reach. :-p
Incidentally, the standard technique given in The Bob's answer, can be extended to more than three bulbs. Eventually, it gets silly, but it would probably be possible to differentiate between 5 or so bulbs, by the method he describes.
So if you were going to leave say three bulbs on, for different periods of time before turning them off, would you :
1) Turn on bulb1; wait 5 minutes and turn on bulb2; wait 5 more minutes and turn on bulb3; wait a final 5 mins, turn them all off
OR
2)Turn on all bulbs; wait 5 minutes and turn off bulb3; wait 5 more and turn of bulb2; wait a final 5 mins and turn off bulb1 ?
You see I have that one covered as well. I am 2.02m and so there are very few ceiling that are too high so I am fine and the answer is fine for me. :-p
The Bob (2004 ©)
Bob indeed has the solution, but I can't see it being extended to more than 3 bulbs. Unless your hands are extremely sensitive to heat differences.
I think bulbs warm up, a lot faster than they cool down. I think the temperature curve, on cooling, is roughly exponential.
I'd want to do an experiment to see how long a bulb had to cool before I couldn't feel any difference between it and one that had never been on. Then I'd take half that time for one bulb, and keep halving thereafter for the others.
Say it takes 8 minutes for a bulb to cool till I can't reliably tell it's been on. Then I'd try 4 minutes of off time for bulb A, 2 minutes for bulb B, one minute for C, 30 seconds for D and 15 seconds for E. I guess the time taken to run between the rooms, and feel the bulbs would make it difficult to go beyond that.
Bulb F would be left on, and G would be always off.
If the bulbs take an apreciable time to heat up (which I doubt) then you could also have two or more 'on' bulbs, identified by their differing temperatures.
C'mon ! You can tell the difference between warm, hot and yaaoouuuch
well, i had actually solved this in seventh grade.
but i would still like to know how ceptimus would solve it, given that we are not allowed to touch the bulbs.
ceptimus said:
Hmmm...
Now that one is really good, at least that's what I think.
Let me just put my version of the answer down, because I did pose the question.
1. Switch on switch 1, wait for 10 minutes and turn it off.
2. Switch on switch 2 and leave for the other room.
3. The hot bulb is connected to switch 1, the glowing bulb to switch 2 and the off bulb to switch 3.
Well I think I have it if you are not allowed to touch the ligthbulbs. Assuming the three lightbulbs are like the once made before Willis Whitnew (in 1903) then you can tell which is which by the same method but the one that has been turned off will be darker than the one that was never one because carbon will have darkened the glass of the bulb. :biggrin:
The Bob (2004 ©)
Modern lightbulbs also go blacker by the time they burn out, This was the basis of my first answer.
i think a similar question was put up here before also. i think it was about 8-10 months back, but that question said that the bulbs were water cooled, or something like that
  • · Replies 17 ·
