Problem with old and New angular speed help me please
The discussion focuses on calculating the new angular speed and kinetic energy of a student on a rotating stool after pulling weights inward. Initially, the student has an angular speed of 0.746 rad/s with weights positioned 1.09 m from the axis of rotation. The moment of inertia of the system is 2.92 kg·m². When the weights are pulled to 0.307 m, the conservation of angular momentum is applied, leading to the equation I_iω_i = I_fω_f to find the new angular speed.
  • Understanding of angular momentum conservation
  • Familiarity with moment of inertia calculations
  • Knowledge of angular speed and kinetic energy formulas
  • Basic physics principles related to rotational motion
  • Study the derivation of the moment of inertia for various shapes
  • Learn how to apply conservation laws in rotational dynamics
  • Explore kinetic energy calculations in rotational systems
  • Investigate real-world applications of angular momentum in engineering
Students in physics, educators teaching rotational dynamics, and anyone interested in understanding the principles of angular momentum and its applications in real-world scenarios.
coey
I'm kinda having trouble figuring out this problem... i was thinking of doing a system of equations to relate the present angular and new angular speed but that didn't really get me anywhere because i wasn't really including all the variables in the problem... that and i couldn't simplify it down to one variable to solve for. If anyone could help me out i'd appreciate it a lot.
A student sits on a freely rotating stool holding two weights, each of mass 2.92 kg. When his arms are extended horizontally, the weights are 1.09 m from the axis of rotation and he rotates with an angular speed of 0.746 rad/s.
The moment of inertia of the student plus stool is 2.92 kg · m2 and is assumed to be constant. The student pulls the weights in horizontally to a position 0.307 m from the rotation axis.
Question: Find the new angular speed and find the kinetic energy before and after he pulls the weight inward.
Whats changing here is the moment of inertia of the weights. They are originally at distance 1.09m and are contracted to 0.307m. Find this new moment of inertia.
Then since momentum is conserved in the system, you can find the new angular speed by:
[tex]I_i\omega_i = I_f\omega_f[/tex] solved for [tex]\omega_f[/tex]
Just to concur with whozum:
You need to use conservation of angular momentum:
[tex] L_i = L_f[/tex]
Where:
[tex] L = p\times r[/tex]
  • · Replies 17 ·
  • · Replies 20 ·
9K
