Calculating Energy Waste of Making 4 Coffee Cups/Day
The discussion revolves around calculating the energy waste associated with making coffee, specifically focusing on the energy required to heat excess water that is not used. The subject area includes thermodynamics and energy calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the energy wasted by heating water beyond what is necessary for making coffee, questioning the formula for energy calculation and the assumptions regarding temperature changes and mass of water.
Participants have engaged in a productive exploration of the problem, discussing the specific heat capacity of water, the mass of water in a cup, and the temperature change involved. Some guidance has been offered regarding assumptions and calculations, although there is no explicit consensus on the final energy cost calculation.
There are ongoing discussions about the assumptions made regarding the temperature difference and the mass of water per cup. Participants are also considering how to estimate the cost of the energy wasted, indicating a need for further information on energy pricing.
suf7
HI I am really stuck with this question, i don't know what to do with it??..can anyone help??..id like to learn how to solve this question...thanks.
A man makes two cups of instant coffee four times a day. On every occasion he fills the kettle up to the 10-cup level. What is the cost of the energy he wastes in one year by heating more water than is necessary??..make suitable assumptions to solve.
Pleeeeeeeeeez help me!
Every time he makes his coffee the man "wastes" the energy required to heat the 8 cups of water he doesn't use. How much energy does it take to raise the temperature of 8 cups of water from room temperature to boiling?
i don't know how to work it out??...what formula should i use??
Is this the formula??...
Energy = M x C x Change in temperature
Room temp is roughly 15 C
Boiling temp = 100 C
So change in temp = 85 C
C, specific heat capacity for water = 4190
Not sure about "M" if this is the right formula?
All of this is quite reasonable. (Note: 15 degrees C = 59 degrees F) Take care to use proper units. The specific heat of water is in J/kg. To find M: What is the mass of a cup of water?
When you put it all together, you'll need to figure how many (unnecessary) cups of water the man heats in a year.
Thanks...but i don't know how to work out the mass of a cup of water??
Come on... don't be lazy! How many ounces in that coffee cup? (Make a reasonable assumption!) 1 fluid ounce is about 30 cm^3; the density of water is 1 gram per cm^3.
so should i get a cup and measure its weight, then fill it with water and measure the weight again, subtract one from the other and il have the mass of water??..then i should convert the value accordingly??
Why go to all that trouble? (Though you can if you have a scale handy!)
Just guess as to how many ounces of water in each cup! (1 standard cup = 8 fluid oz.) Then use the data I provided to find the mass (in kg) of that cup of water.
ok so does that mean that the mass of water per cup works out at 0.24kg so the amount of water being wasted evrytime he makes his 2cups is:
E = M x C x CIT
= 1.92 x 4190 x 78
= 627494.4 j (This is for ONE boiling of the kettle)
so that means that in a day the energy being wasted is 2,509,977.6 j
so in a year would be 2,509,977.6 j x 365 = 916,141,824 j
does that seem correct?
Sounds good to me. It looks like you changed your assumption about the temperature difference from 85 degrees to 78 degrees. But no matter; the point is to give a reasonable estimation of the energy wasted. Since we're just estimating anyway, I'd round off that final answer. Given your assumptions, the energy wasted is approximately 900 million joules per year! (If you stuck with your first assumption -- 85 degree change -- the answer would be about 1 billion joules.)
wow, it actually looks right??..thanks for your help..so for the final part how would i work out the cost of that energy?..??..i went to the npower website to find out some figures but its all so confusing??
  • · Replies 16 ·
15K
  • · Replies 25 ·
  • · Replies 23 ·
9K
10K
