What is the normal reaction on the box in equilibrium on an inclined plane?
  • Thread starter Thread starter Gughanath
The problem involves a box of mass 6 kg on a rough inclined plane at a 30-degree angle, held in equilibrium by a horizontal force P. The coefficient of friction is 0.4, and the box is on the verge of moving up the plane. The objective is to find the normal reaction exerted by the plane.
  • Mixed
  • Participants discuss the concept of limiting equilibrium and the role of friction in determining the normal reaction. Some suggest resolving forces into components, while others express confusion about incorporating the horizontal force P into their calculations.
Several participants have shared their equations and reasoning, with some confirming the correctness of each other's approaches. There is ongoing exploration of how to incorporate the frictional force and the horizontal force into the equilibrium equations, with no explicit consensus reached yet.
Participants note potential issues with the accuracy of textbook answers and the importance of careful trigonometric calculations in resolving forces.
Gughanath
Another problem I can't solve
A box of mass 6kg lies on a rough plane inclined at an angle of 30 to the horizontal. The box is held in equilibrium by means of a horizontal force of magnitude P Newtons.
The coefficient of friction between the box and the plane is 0.4.
Find the normal reaction exerted on the body by the plane.
The box is in limiting equilibrium and on the point of moving up the plane. :confused:
You know that in limiting equilibrium, the frictional force is [itex]F = \mu R[/itex], where R is the normal reaction.
The box is in equilibrium, but if it were to move, it would move up the plane. That should tell you in which direction the forces on the box are (or rather, if they're in the same direction, or in opposite directions).
Draw a diagram, those help loads in A Level Maths!
Edit: you don't even need all that info to find the normal reaction. Resolve the weight into components parallel and perpendicular to the slope and you can get the normal reaction from that.
but the force P (which is unknown at the moment) will also need to be taken into consideration. If I resolved into perpendicular components it becomes Pcos60 +6gcos30 = R?
Ahh, sorry. I didn't see that horizontal force bit. Yes, you're right about that.
I included P in my equations and then elinated it. But I don't get the right answer. What would be your suggested method?
Post your working, then we can see where you've gone wrong (if anywhere!). You're not using Edexcel books are you? Sometimes they get the answers wrong.
Resolving perpendicualr to the plane:
R = Pcos60 + 6gcos30
Resolving parallel to the plane:
Fr (friction) = Pcos30 - 6gcos60
is this right so far?
Write the equations representing the equilibrium condition for forces parallel and perpendicular to the plane. You'll get two equations and two unknowns (P and the Normal reaction); solve for N.
Yep, looks ok to me.
and Fr (the friction will also be in the equation which is the problem.
Why is the frictional force a problem?
But the friction can be written in terms of R. Since it is just about to move, the static friction will equal its maximum value [itex]F_r = \mu R[/itex], as was pointed out by Nylex in his first post in this thread.
ok. I just did everything again. And I found out that I went wrong with the sins and cos during the calcualtions. My value for R comes out to be 88.3N which is correct.
Yes I used Fr = uR
The last point tells you that the actual friction force is the maximum static friction force (ie. exactly the coefficient of static friction multiplied by the normal force). The components of force along and perpendicular to the plane are:
Parallel to plane:
(1) [tex]mgsin(\theta) + Pcos(\theta) + \mu_s N = 0[/tex]
Perpendicular:
(2) [tex]mgcos(\theta) + Psin(\theta) = N[/tex]
Substitute N from (2) into (1) to solve for P in terms of mg and [itex]\theta[/itex]:
[tex]mgsin(\theta) + Pcos(\theta) + \mu_s (mgcos(\theta) + Psin(\theta)) = 0[/tex]
[tex]mgsin(\theta) + \mu_smgcos(\theta) + P(cos(\theta) + \mu_ssin(\theta)) = 0[/tex]
[tex]P = \frac{-(mgsin(\theta) + \mu_smgcos(\theta))}{cos(\theta) + \mu_ssin(\theta)}[/tex]
Substitute that into (2) to get N.
AM
yep...thanx...works
  • · Replies 20 ·
