How to Determine if a Glass was Broken from Inside or Outside
  • Thread starter Thread starter vabamyyr
    Glass
The discussion revolves around methods for determining whether a glass was broken from the inside or outside, referencing forensic techniques and the properties of glass. It also touches on the classification of glass as a solid or liquid, exploring both scientific and practical perspectives.
  • One participant describes a forensic analysis from a CSI episode, mentioning "Haeckel marks" as a potential method for determining the direction of glass breakage, but seeks clarification on the technique.
  • Another participant provides links to external resources, possibly related to forensic glass analysis.
  • A separate question is raised about whether glass is a liquid or a solid, with references to the appearance of old stained-glass windows.
  • One participant argues that the notion of glass flowing over time is incorrect, attributing thickness variations in stained glass to manufacturing processes rather than flow.
  • There is a discussion about classifying glass as an amorphous solid versus a highly viscous liquid, with some participants noting the complexity of this classification.
Participants express differing views on the classification of glass, with some supporting the idea of it being an amorphous solid and others suggesting it may be a highly viscous liquid. The discussion on forensic methods remains unresolved, with no consensus on the specifics of the techniques mentioned.
The discussion includes references to specific forensic techniques and the properties of glass that may depend on definitions and interpretations, which are not fully resolved within the thread.
vabamyyr
I saw CSI today and a glass was broken on the crime scene and furensics took one sample fracture from there and did one experiment in the laboratory also. (experimentor broke a window (glass) with baseball bat). And then they analysed those 2 fractures(one from scene and one from lab) and determined that the glass broken on the crime scene was done from the inside not from outside which would refer to burglary. But i couldn't figure out how. They talked about some Haeckel marks? and i typed it into google search and found nothing. Anyway can someone tell me the method determing whether normal window (glass) is broken from inside or outside, or is my question too confusing?
http://www.stanford.edu/~zhongj/SGKBweb/def/joiSurMor.html
http://members.aol.com/JRD203/csi-episode-010.htm
Enjoy.
i also have a question about glass: is it a liquid or a solid?
because i read something that claimed it is now considered a liquid with high viscosity, since old stain-glass windows appear to "run".
The thing about glass flowing in churches is untrue. The reason that such glass is thicker at the bottom is due to the manufacturing process. This glass was generally blown, flattened, and then spun, meaning that the glass was thicker on the outside of these big discs. The glass was then cut up into sheets, and when installed, common sense led to the glass being installed with the thick (heavy!) side at the bottom.
The answer to the question "is glass liquid or solid" is not a clear one, and if you use the search facility you will see some rather long debates presenting both sides of the argument. For engineering purposes, I like to class glass as an amorphous solid, although there are arguments for it being a highly viscous liquid, and some class a "glass" as being a separate category altogether.
brewnog, thanks for the clarification.
i can remember when there were just 3 forms of matter, solid/liquid/gas..those days are long gone. :smile:
For most practical purposes, it's still prudent to make a distinction between those three states. I'd always treat glass as a "solid" (unless it were molten :smike:)
  • · Replies 19 ·
11K
11K
