Can You Solve These Challenging Microsoft Interview Riddles?
  • Context: Undergrad
  • Thread starter Thread starter z-component
    Interview
The discussion revolves around three riddles presented in a Microsoft job interview, focusing on problem-solving strategies and reasoning. The riddles involve identifying patterns, optimizing crossing times with constraints, and timing with burning fuses. Participants explore various approaches and interpretations of the riddles without reaching definitive conclusions.
  • Riddle #1 involves identifying a pattern in a sequence, with some participants suggesting it relates to the Conway sequence.
  • For Riddle #2, various crossing strategies are proposed, with some participants suggesting a total crossing time of 17 or 18 minutes, while others argue for 19 minutes based on their interpretations of the rules.
  • Participants debate the implications of the phrase "nobody can go alone," with differing views on whether it allows for one person to return with the flashlight while another crosses.
  • Riddle #3 discusses timing 45 minutes using two fuses that burn at different rates, with one participant suggesting igniting one fuse at both ends and the other at one end.
  • Some participants express confusion over the assumptions made in the riddles, particularly regarding the number of flashlights and the crossing rules.
Participants do not reach a consensus on the solutions to the riddles, with multiple competing views and interpretations remaining throughout the discussion.
Participants highlight ambiguities in the wording of the riddles, particularly regarding the crossing rules and the necessity of the flashlight, which contribute to differing interpretations and solutions.
Individuals interested in problem-solving, logic puzzles, and interview preparation may find this discussion relevant.
z-component
These three riddles appeared during a certain Microsoft job interview.
The interviewer would watch how the interviewee responds to these riddles. Even if they didn't get the answer, the interviewer wants to see how they think as they explain the steps they're making to TRY to solve it. Some might be too easy to solve directly! See if you can solve these.
Riddle #1:
2 1
1 2 1 1
1 1 1 2 2 1
3 1 2 2 1 1
What's the pattern?
Riddle #2:
You have four people at a bridge... one HAS to carry a flashlight as they cross, but only two can cross at a time. And nobody can go alone.
It only takes one 1 minute to cross. Another takes 2 minutes. Another, 5. And the last, 10.
If the person who takes 1 minute goes with the person who takes 10... it automatically takes 10 minutes.
How many minutes will it take them all to cross.. at the quickest?
Riddle #3:
You have two fuses... they burn at different rates and not at steady rates. BUT! They only burn for one hour. One could burn the entire way except one inch within one minute, then spend the last 59 on that last inch, for example.
You also have to use this to somehow time 45 minutes exactly. How would you do it?
Mathematics news on Phys.org
Ignite string A on both ends, string b on one end. When string A burns out, ignite string B on both ends.
2.
17[/Color]
-- AI
Where are you getting your answer of 17 or 18 for question 2??
This is my answer and reason...
19 Min
1&10 cross 1 comes back 11min, 5&1 cross 1 comes back 6 min, 2&1 2 min = 19 min
How can it be done faster?
how does one get the pattern for 1?
z-component said:
Riddle #2:
12 minutes. 10 & 5 cross, =10 minutes then 2 & 1 cross =2 minutes
20questions said:
<snip>answer</snip>
Oh ofcourse, they throw the flashlight from one end to the other, how in the world i didnt think of this :wink:
max(1,2)+min(1,2)+max(5,10)+min(2,5,10)+max(1,2)=17[/Color]
Sorry if i am cryptic, but this was supposed to be a brain teaser :wink:
-- AI
-- AI
Why would you assume there is only one flashlight? Post said A flashlight not THE flashlight. If not two would have to cross and then two cross back (if one can't cross alone one shouldn't be able to cross back alone) and all 4 would never all get across
Point taken and understood. But then it wouldn't be much of a brain teaser would it be?
quoting the question,
Only two can cross at a time
I believe this means, "at the max only two people can cross at one time" and not "exactly two people should cross the bridge at any instant".
-- AI
very clever tenai...but then by your logic..it would only take 10 mins.
i guess it all depends on your take of "noone can go alone"
oh and could you please tell me or hint to solve 1...
Really :confused:
Google for Conway sequence, its one of the well known sequence and according to one paper (which is not freely available unfortunately) this sequence has many interesting properties.[/Color]
-- AI
Tenali, are you saying this?
The 1 minute person has the flashlight. 1 min + 10 min cross, then 1 min + 5 min cross, then 1 min + 2min cross. = 17 mins. Now when I say 1 min + 5 min cross, I mean that 1 min is coming back to the start while 5 min is going to the end.[/color]
Probably easier to see in this image: http://img11.imageshack.us/img11/28/msquestion3oa.gif
There is no trick to breaking the rules- two people max, both same way, one flashlight. The trick is to illiminate the bad affects of the 10 and 5 person- think of the farmer, the fox, the chicken, and the egg riddle if you know it...
3) light one rope at both ends
<snip>
Err nope,
(warning : spoiler)
Assume a,b,c,d are on the left side.
Objective -> a,b,c,d to go to right side in minimum time
Constraints -> Just one flashligh, flashlight necessary to cross and bridge can balance at the max 2 people
a(1 min,flashlight),b(2 min) go right --> 2 mins
a(1 min,flashlight) goes left --> 1 mins
c(5 min,flashlight),d(10 min) go right -> 10 mins
b(2 min,flashlight) goes left --> 2 mins
Total -> 2+1+10+2+2 = 17 mins
[/Color]
-- AI
this was my solution..i'm not going to white it because its a matter of the way you interpret the question. 10min carries flashlight.5+2+1+1+1=8 = 10.
-- AI
(Agreed, but it was the 'nobody one can go alone' line that, for me, ruled out someone crossing either way alone. Hmm, perhaps 'go' may be just mean 'go' and not 'come back'. Two people on the bridge at the same time, even if one's crossing leftward and one's crossing rightward may be legal to the rules as I saw them though.
The 3rd line implied to me that the faster person must walk slow to actually stay with the slower person, i.e. hand in hand.
Knowing other puzzles on this board maybe one of the crossers is named Nobody! )
20questions said:
(Agreed, but it was the 'nobody one can go alone' line that, for ... <snip> Knowing other puzzles on this board maybe one of the crossers is named Nobody!)
Oh well, poorly defined question, yeah probably. I guess, your solution stands good given that the concerns you have raised seem appropriate :smile:
-- AI
I didnt notice the nobody can go alone line but if that were true the question would be impossible.
^ Yes exactly! That is why I think one comes back, with the flashlight, while another crosses at the same time. They are not together, but they are crossing the bridge at the same time.
-- AI
Tenali, you solved the problem as it should have been written. You didn't read the way it was actually written closely enough.
"You have four people at a bridge... one HAS to carry a flashlight as they cross, but only two can cross at a time. And nobody can go alone."
As written, it pretty much makes the problem unsolvable unless you either have two flashlights or get to throw the only flashlight.
I did accept it didnt I? Though i do believe your comment came just after read the first page and prolly didnt realize there was a second page. (I have made this mistake one time too many).
-- AI
tenali you solution doesn't have two people crossing between steps 4,5
<snip>
These are all quotes from previous posts.
Maybe it was not understood as to what i meant by "i did accept it" ??
I accepted that 20questions' concerns were correct and so was his answer, in which case my solution becomes null and void. Should i detail out how i am wrong and when i would have been right?
To make it clear as to what happened so far,
1. I proposed a solution
2. 20questions proposed a solution
3. 20questions convinced me how he was right, given the way the question was framed
4. I accepted his answer completely, (which means i accepted that my answer won't work the way the question was framed (maybe i should bold this statement hmm?) )
5. However, in my answer, i distinctly cleared what objectives and constraints of the problems i have taken into considerations, which shows when my solution would have worked.
-- AI
P.S -> Also in my solution, there is just one man crossing even in step 2 and not just in step 4.
P.S2 -> I WAS WRONG! (This is for those who are expecting it!)
Other versions of this puzzle (e.g. here - there is nothing new under the sun), don't have the "no one can go alone" restriction, and without that TenaliRaman is correct. With it I would say that the problem is impossible. Maybe Microsoft decided that that was what they wanted, like the interviewee being asked into the room and told to sit down, but finding that there isn't a chair (anywhere). I can well believe that Microsoft might stress out their candidates in that way
Riddle #1:
2 1
1 2 1 1
1 1 1 2 2 1
3 1 2 2 1 1
What's the pattern?
This one's been on here a bunch of times. Actually, the last time I saw Microsoft riddles, they were a lot harder than these. Are you sure these are Microsoft riddles? Anyways:
1 3 1 1 2 2 2 1
Riddle #2:
First 1 and 2 go across, then 1 comes back. Then 10 and 5 go across and then 2 comes back. Then 1 and 2 go across. Total time: 2 + 1 + 10 + 2 + 2 = 17.
I have a strong feeling these aren't even Microsoft riddles. I've seen these before, some of them quite a while ago, and never thought they were from Microsoft.
Riddle #3:
Take fuse A and light both ends. At the same time, light only one end of fuse B. Fuse A will extinguish after precisely half an hour. At the exact time that it extinguishes, ignite the other end of fuse B. When fuse B has extinguished, exactly 45 minutes will have elapsed.
Maybe by "no one can go alone" he means "no one can go without the flashlight (or without a partner who has it)."
It says one has to carry a flashlight, it doesn't say that everytime someone crosses they have to carry a flashlight, send 1 and 2 with the light, then followed after by 5 and 10, not carrying a flashlight.
there are 4 flash light and each one has a flash light
10 and 1 go
by the time 1 reach the end, 2 go instantly. So 10 is togather with the 2
by the time 2 reach the end, 5 go instantly. So 10 is togahter with the 5
then 5 walk slowly so that they reach the end togahter with the 10
so 10 minutes right?
The correct answer to the second riddle is found using AKG's method.
1. You're right that it can't be done if they can't throw the flashlight across unless they meant just that at least two people needed to cross. If that's the case, then you wouldn't need to throw the flashlight, and it would take you 17 minutes.
2. I figure that since it doesn't specify, have person A carry person D across since person A can cross in one minute you have only taken one minute. Then throw the flashlight across to person B who takes two minutes to carry person C across. You have a total of 3 minutes to cross. Because person A doesn't "[go] with" person D, they CARRY person D, and person B CARRIES person C. I'm sure this isn't what they were referring to; but hey, I think it works.
  • · Replies 27 ·
  • · Replies 35 ·
10K
