Airline industry and the future of oil
The discussion revolves around the future of air travel in the context of depleting oil supplies and the potential for alternative fuels, particularly hydrogen, LNG, and ammonia. Participants explore the feasibility of modifying jet engines to accommodate these fuels and the implications for aircraft design and operation.
  • Some participants express skepticism about the practicality of hydrogen-powered aircraft, questioning the feasibility of large-scale implementations like a hydrogen-powered 747.
  • Others propose that jet engines could be modified to burn hydrogen, citing examples of gas turbines in power plants that already use natural gas.
  • Concerns are raised about the high combustion temperatures of hydrogen and the need for engine modifications to handle these conditions.
  • Storage issues for hydrogen are discussed, including the challenges of liquefaction and the risks associated with its flammability.
  • Some participants mention alternative fuels such as LNG or ammonia, noting that there are technical, economic, and safety issues to consider with these options.
  • There is a suggestion that Fischer-Tropsch synthesis could be a method to produce synthetic fuels from hydrogen and CO2.
  • Historical references are made to the SR-71's initial design plans, which included burning hydrogen, highlighting the trade-offs between energy density and aircraft size.
Participants do not reach a consensus on the best approach for future air travel fuel sources. Multiple competing views remain regarding the viability of hydrogen and other alternatives, as well as the implications of depleting oil supplies.
Participants express uncertainty about the future availability of oil and its impact on airline pricing. There are also unresolved questions regarding the technical feasibility of proposed fuel alternatives and the modifications required for existing aircraft engines.
Pengwuino
One thing that I've absolutely never seen brought up is how aircraft will be effected by depleating oil supplies. We figured out that we can go to hydrogen powered cars when we figure out all the kinks in the system and setup a mass distribution system... but what about aircraft? I just can't imagine a hydrogen powered 747 or any nuclear engines anytime down the road...
So what are the plans for the future of air travel? Or does air travel use so little oil that we can use natural processes that already happen to create enough fuel for them
Jet aircraft run on various grades of jet fuel, which is essentially kerosene. I've seen one mentioned recently (in this site, I believe) that was run on deisel fuel with little or no modification. It shouldn't be too hard to adapt one to burn hydrogen. As for storage, the most efficient method that I'm aware of is magnesium hydride blocks. Pure magnesium absorbs hydrogen when chilled and releases it when heated. The storage density is 1gm/cc, which is higher than liquid hydrogen. This is a thread in which FredGarvin should probably make the deciding posts.
Can you burn hydrogen in a jet engine with some mods??
The jet engine would have to be innovated.
Sure. The gas turbines in generator plants are just jet engines burning natural gas. The turbopumps in most liquid-fuel rocket engines, or the turbochargers in cars or planes, are extremely simplified jet engines. Pretty much anything that can be injected, ignited, and will hold a reasonable combustion front at the flame-holder area is appropriate. Since hydrogen has the highest efficiency of any fuel, it stands to reason that burning it will be cheaper than using something like Jet-A. Modifying an engine to use it should be no harder than converting a car from gasoline to propane.
Adding to what Danger mentioned, gas turbines in power plants already burn natural gas (methane) so burning hydrogen would not be a problem.
However, hydrogen burns very hot - so the combustors would have to be designed to accommodate high temperatures.
Also, a major issue will be storage, especially if hydrogen is liquified. Cold LH2 would cause moisture to condense (a problem with the space shuttle), cold temperatures pose a problem for metal fatigue, and hydrogen gas is highly flammable. Possibly LNG or ammonia could be used as a fuel, but there are technical, economic and safety issues to be considered.
How about using kerosene as fuel?
Perhaps have another look.
You don't hear about drastically fluctuating airline pricing? The idea of depleting is misleading. The first day man drilled for oil, technically the oil supply was depleting.
Take a look at Project Pluto from back in the late 50's-early 60's.
Ok what i meant to say was CNN has never said anything :P
Nope, never have...although i have been rather low on my daily tv allowance as of late. And when i said depleting, i meant as far as it coming to a point where we don't have any left So scratch depleting, insert... uhm...dang it i just woke up after 3 hours of sleep ... whatever word means not have much of, insert that :smile: :smile:
Im still talkinga bout the costs as oil becomes uhh, dissappeared :D
Jet fuel is pretty much kerosene, which is derived from oil. Pengwuino's question concerned what happens when oil runs out.
One could in theory use Fischer-Tropsch synthesis to make heavier alkanes from a feedstock of hydrogen and CO2.
The initial plan for the SR-71 was to have it burning hydrogen. Liquid hydrogen is a double-edged sword: it has a high energy density (energy per pound) but a low density (mass per pound) so while planes powered by hydrogen would be lighter (and thus require much less energy to fly) than traditional planes, they'd also need to be much larger: the first design for the SR-71 had it 300 feet long.
  • · Replies 23 ·
  • · Replies 39 ·
18K
