Power of Consecutive Fans: Double the Speed?
  • Context: High School
  • Thread starter Thread starter Mk
The discussion centers around the behavior of air flow when using two hurricane fans in series versus parallel configurations. Participants explore the implications of fan arrangement on air speed and flow characteristics, touching on concepts relevant to engineering and fluid dynamics.
  • One participant questions whether placing two hurricane fans in series will result in air speed being doubled.
  • Another participant asserts that the speed of the second fan will not increase the air speed to twice that of the first fan.
  • A third participant clarifies that while series arrangement doubles the head, it does not double the flow rate, which remains equivalent to a single fan.
  • It is suggested that placing fans side by side (in parallel) would create a greater area of effect rather than increasing speed.
  • A participant draws an analogy between fluid flow and electrical flow, emphasizing the relationship between pressure and flow in different configurations.
Participants generally agree that the arrangement of fans affects flow and pressure differently, but there is no consensus on the implications for air speed specifically. Multiple competing views remain regarding the effects of series versus parallel configurations.
Participants reference concepts such as head, flow rate, and the analogy between fluid dynamics and electrical flow, but do not resolve the complexities of these relationships or their implications for fan performance.
Mk
If you have two hurricane fans, and place them one after another, both blowing the same direction, will the air from the front fan be twice as fast?
Well, I don't know what a hurricane fan is, but the answer is no.
The speed of the second fan relative to the air will not cause the air to speed up twice as much.
Dave is right. When you have equal characteristics fans(i.e equal head and flowrate) series arrangement gives you the capacity of a single fan but head gets doubled. Parallel arrangement gives you double the capacity of a single fan but head remains same.
The fan speed will not increase by putting one behind another, but by putting them next to each other will create a greater area covered and more of a "breeze" effect. Both Dave and quark were correct
Well, there was recently a thread where someone complained about water flow being used as an analogy for electricity. Well, here it is again: as others correctly said - parallel vs series configuration means more flow (amperage, flow) vs more pressure (voltage, head).
edit: If you internalize this concept (that energy transfers/flows of all types are related), you'll be waaaaay ahead of the curve as an engineer.
  • · Replies 32 ·
  • · Replies 30 ·
