Q-factor in resonant RCL circuit
  • Thread starter Thread starter temujin
    Circuit Resonant
The discussion revolves around the calculation of the Q-factor in a resonant RCL circuit, specifically one that resonates at 13.56 MHz and is tuned to a 50-ohm input impedance. Participants explore the role of the circuit components, particularly the capacitors and inductor, in determining the Q-factor.
  • One participant, eirik, proposes the formula Q = \frac{\omega L}{R_{a}+R_{coil}} for calculating the Q-factor but questions why the capacitors can be disregarded in this context.
  • Another participant suggests that the leftmost capacitor is likely for coupling purposes and emphasizes that the resonance frequency is a function of capacitance, implying that the capacitors play a role in the overall behavior of the circuit.
  • A later reply posits that the total reactive energy in the circuit is constant and questions whether, at resonance, the energy can be considered solely in the inductor at certain instants when it is at maximum, suggesting a potential simplification in the analysis.
  • Additionally, a participant references the relationship \omega = \frac{1}{\sqrt{LC}} to connect the inductor and capacitor values to the resonance frequency, indicating that both components are relevant to the Q-factor calculation.
Participants express differing views on the role of the capacitors in the Q-factor calculation, with some suggesting they can be disregarded while others argue for their significance. The discussion remains unresolved regarding the treatment of reactive energy in the circuit.
There are unresolved assumptions regarding the treatment of energy storage in the capacitors versus the inductor, and the implications of the coupling capacitor on the overall circuit behavior are not fully explored.
temujin
Dear Forum,
I am not sure how I can calculate the Q-factor in the circuit attached.
(The circuitresonates at 13.56MHz and tuned to 50 ohm input impedance, thus the two capacitors)
Is the Q-factor of the circuit simply [tex]Q = \frac{\omega L}{R_{a}+R_{coil}}[/tex] ?
I went through some examples and it looks like this is the right way to do it, however, I´m not sure why the capacitorscan be disregarded, since they also store reactive energy.
best regards
eirik
The left most capacitor is probably used for coupling purposes. Don't forget that the omega term is the resonance frequency, which is indeed a function of the capacitance. It's quite a mess, but I think if you derive the equations based on first principles (3db amplitude drop - bandwidth), you will see why this is so.
Hi again,
One additional thought...I think that the total reactive energy in the circuit is constant. At resonance the total energy swings back and forth between the capacitors and the inductor. Can it be that at one instant when the stored energy is at maximum in the inductor, the stored energy is zero in the capacitors? So that I just need to consider the inductor at that instant??
e.
temujin said:
Hi again,
e.
As mezarashi said, [tex]\omega = \frac{1}{\sqrt{LC}}[/tex], so [tex]\omega L = \sqrt \frac{L}{C}[/tex]. There you have both L and C.
  • · Replies 32 ·
  • · Replies 28 ·
