How to Determine Final Temperature and Enthalpy Change During Vaporization?
  • Thread starter Thread starter physicsCU
    Thermo
The discussion revolves around determining the final temperature and enthalpy change during the vaporization of water in a piston-cylinder setup, with specific conditions provided such as volume, temperature, pressure, and mass.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to apply the ideal gas equation and considers using enthalpy change based on mass and specific enthalpy of vaporization. Some participants suggest consulting water tables and Mollier diagrams for accurate enthalpy values, while others question the appropriateness of the initial approach.
Participants are actively engaging with the problem, with some providing guidance on using thermodynamic tables and questioning the assumptions made by the original poster. There is recognition of the need to clarify the physical understanding of the process involved.
There is mention of specific values and conditions, including the pressure being held constant during the heating process, which may influence the interpretation of the problem. The original poster acknowledges missing information from their resources, such as pressure tables.
physicsCU
OK, I have a piston-cylinder with water.
V = 50L = 0.05 m^3
T = 25 C
P = 300 kPa
m = 49.85 kg
specific volume @ 25 C = 0.001003 m^3/kg
The water is heated to vaporization with pressure held constant. I need to determine the final temperature and the enthalpy change.
I know what the answers need to be (133.55 C and 103,627 kJ). On the temperature, I tried doing T = (PV/mR), using R = 0.4615 (kPa*m^3)/(kg*K), but i didn't get anywhere close.
On the enthalpy change part, I figured using m*h_fg, but that isn't right (I think).
Any ideas? Thanks a lot!
V = 50L = 0.05 m^3
T = 25 C
P = 300 kPa
m = 49.85 kg
1) Look at the water tables to see what enthalpy has the initial state,
2)The thermodynamic trajectory is an isobaric one until you have reached a 100% of water vapor inside cylinder. Look at a Mollier diagram or go to tables to localize the enthalpy of water vapor at 300Kpa. Then you have the enthalpy difference.
3) do not use the equation of state as you've done. It shows you didn't understand the problem at all. Imagine it physically: you are heating water to vaporize it with a free piston, do you really think volume is going to remain constant?
OK, I got the enthalpy difference, no problems.
I didn't realize my book had a pressure table, I found it there. Duh.
I neglected to mention that I looked at the v_fg values as well, and that didn't work. Sorry about that.
THANKS so much for your help. No wonder you are an engineer guru!
You're welcome!. Doubtless, there are another people who just wonder why the hell I am the PF eng. gurú.. :smile: To those...maybe they're right. :biggrin:
  • · Replies 16 ·
