Solve Vibrating String Differential Equation with d'Alembert's Method
The discussion focuses on solving the vibrating string differential equation using d'Alembert's method. The specific problem involves finding u(1/2, 3/2) with parameters l=1, c=1, f(x)=0, and g(x)=x(1-x). The correct approach requires applying odd extensions to the function g(x) over the integration interval, resulting in the equations g_1(x) and g_3(x) for the respective intervals. The final calculated result for u(1/2, 3/2) is -1/12.
  • Understanding of d'Alembert's solution for wave equations
  • Knowledge of odd extensions in function analysis
  • Familiarity with integral calculus and definite integrals
  • Basic concepts of vibrating strings in physics
  • Study the application of odd extensions in Fourier series
  • Learn about the derivation of d'Alembert's formula for wave equations
  • Explore advanced techniques in solving partial differential equations
  • Investigate the physical implications of vibrating strings and wave propagation
Mathematicians, physicists, and engineering students interested in wave equations, particularly those studying the behavior of vibrating strings and differential equations.
stunner5000pt
Of the Partial Kind :smile:
Using d'Alemberts soltuion for the vibrating string in one dimension
Find u(1/2,3/2), when l-=1, c=1, f(x) = 0, g(x) = x(1-x)
Now i tried simply substituting this into the solution that is (since f(x)=0)
[tex]u(x,t) = \frac{1}{2} \int_{x-t}^{x+t} g(x) dx[/tex]
but it yields the wrong answer.
Does the length of the string have anything to do with the answer?
Thank you in advance for your help!
Stunner, to use D'Alembert's forumua, you need to remember to use the "odd extensions" of both f(x) and g(x). Now, I know that's not pretty but that's just how it is. Remember when I said that [itex]Sin[\pi x][/itex] was already an odd-extension and so we didn't have to do anything about it? That's not the case with g(x)=x(1-x) over the interval you're integrating from. Look at the first plot. That's g(x) un-extended. We wish to make an odd periodic function of g(x) over the interval of integration. In your case that's 1/2-3/2 to 1/2+3/2 or the interval [-1,2]. So, first thing is to "odd-extend" what the function looks like in [0,1] to the interval [-1,0]. Well, that's the second plot and the equation for it is:
[tex]g_1[x]=x(1+x)[/tex]
The equation for the interval [0,1] is just g(x):
[tex]g_2(x)=x(1-x)[/tex]
Now I wish to do that again for the interval [1,2], that is an odd extension of g(x) which would just be flipping it over into the interval [1,2]. The equation for that one would be:
[tex]g_3(x)=-(x-1)+(x-1)^2[/tex]
The third plot is all three. So:
[tex] \begin{align*}<br /> u(1/2,3/2) &=\frac{1}{2}<br /> \int_{-1}^{2}\tilde{g_0}(\tau)d\tau \\ &=<br /> \frac{1}{2}\left(\int_{-1}^0 g_1(\tau)d\tau+\int_0^1 g_2(\tau)d\tau+\int_1^2 g_3(\tau)\tau \right)<br /> \end{align}[/tex]
I get -1/12. Is that what you get?
Edit: Stunner, I initially made a typo on g3 but corrected it above.
Edit2: Forgot the 1/2 in front of the integral sign. Suppose that's -1/12 now. Sorry.
it is quite clear that we are not being taught (or the material's presentation) correctly. I did not know how to extend the functions. I understand now... thank you very much!
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 20 ·
