Teacher told me that electricity could be defined as a flow of electrons
The discussion revolves around the definition of electricity, specifically as a flow of electrons, and explores the mechanisms behind electrical phenomena such as light bulbs and televisions. It covers concepts related to electric current, potential difference, and the distinction between alternating current (AC) and direct current (DC).
  • One participant recalls a teacher's definition of electricity as "a flow of electrons" and questions what causes this flow when devices are turned on.
  • Another participant explains that a cell or battery provides electromotive force (voltage) that drives electrons through a circuit, encountering resistance, and describes how this results in heating a light bulb's filament.
  • A different viewpoint suggests that 'electricity' encompasses any phenomena caused by charged particles, noting that electric current can also involve positive charges, not just electrons.
  • It is mentioned that completing a circuit allows current to flow, with the battery's terminals creating a potential difference that pushes electrons through the wire.
  • One participant describes the operation of a light bulb and contrasts it with the more complex functioning of televisions, which utilize electron beams to excite screen chemicals.
  • Another participant introduces the concept of alternating current (AC), noting that it involves electrons moving back and forth rather than in a single direction.
  • There is a mention of conduction electrons in metals being responsible for current, highlighting the difference in conductivity between metals and non-metals.
Participants express various viewpoints on the nature of electricity and current, with some agreement on basic principles but also significant differences in understanding AC versus DC and the role of charged particles.
Some participants introduce concepts without fully resolving the distinctions between AC and DC, and there are varying levels of detail regarding the mechanisms of current flow and the behavior of different materials.
sanjuro
teacher told me that electricity could be defined as "a flow of electrons"
When I was much younger, my teacher told me that electricity could be defined as "a flow of electrons". So when I turn on a light bulb or television set, what is actually happening inside? What is making the electrons move? A positively charged field perhaps? But how is the field created? Where is it? What is conventional current?
Not challenging questions, but physics is new subject for me.
Thank you
the cell or battery contains electromotive force, or Voltage, this forces the electrons through substances, with resistance against it, thus making current
(i *hope* I'm right here) when it goes through a lightbulb, the electrons heat up the filament, which is supsended in an inert gas, and thus, it glows.
'electricity' could be used to describe any phenomena caused by charged particles.
electric current is flow of charge resulting from the movement of charged particles. current is a base quantity, although you could define it as the rate of flow of charge with respect to time. in most cases, an electric current takes the form of a flow of electrons, but a current can also be carried by positive charges (such as the positive charges in an electrolyte).
when you turn on a light bulb (powered by a battery for example), several things happen. by pressing the switch, you complete the circuit. current can only flow in a circuit when the circuit is complete.
the battery has two terminals, positive and negative. the positive terminal is positively charged, and the negative terminal is negatively charged. the difference in charge between the terminals is the potential difference (voltage). the potential difference results in an electromotive force which pushes the elcectrons around the wire. you can think of this as follows: free electrons in the wire are attracted to the positive terminal and repelled by the negative terminal (electrons are negatively charged, opposite charges attract each other, like charges repel each other). thus the electrons flow away from the negative terminal and towards the positive terminal.
now that the electrons are moving, there is a current in the wire. the filament in the light bulb has a high resistance. because of the high resistance, the filament heats up a lot when a current is forced through it. the heat energy of the filament is then released (mostly) as light energy.
TVs are quite a bit more complicated. they work by firing beams of electrons onto the screen. there are chemicals in the screen which release light energy when they are excited by the electron beam. i don't think you need to worry any more about this until you have grasped the basics of electricity.
to sum up, the electrons move because of the potential difference between the terminals of the power supply. what's more; the current is directly proportional to the potential difference. if you double the potential difference, you double the current.
conventional current goes from positive to negative. electric current was discovered before the the electron. when they discovered the electron and found that it was negatively charged, they realized that the flow of electrons carrying a current actually went from negative to positive.
AC
The elctricity that we have at home or work or school is (with extremely rare exceptions) alternating current, i.e. the electrons are in constant (60 cycles per second in U.S.) back and forth motion, rather than in one direction.
Yes, the motion is Simple Harmonic.
However, AC current is wildly different from DC.
I think we have to add here that in metals there are electrons free of their atomic shells, conduction electrons, and these are the physical support for current in wires. The lack of these electrons in non-metals is the reason they don't conduct electricity.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 20 ·
