Potential energy of a spring,POTENTIAL ENERGY OF LOADING
The discussion revolves around the concepts of potential energy in springs, specifically distinguishing between "strain energy" and "potential energy of loading." Participants explore definitions and applications of these terms within the context of elastic bodies and engineering principles.
  • One participant states that the potential energy of a spring is defined as 0.5*k*x^2, referring to it as "strain energy," and questions the meaning of "potential energy of loading."
  • Another participant argues that the term "potential energy of loading" refers to the energy associated with the deformation of the spring, suggesting that strain energy is part of this total energy.
  • A different viewpoint emphasizes that "strain energy" is indeed 0.5*k*x^2, while asserting that "potential energy of loading" pertains to the work done by the loading force.
  • A participant mentions that these concepts are relevant in engineering for analyzing material elasticity and crack formations, suggesting that further inquiries might be better suited for engineering forums.
  • Another participant notes that the concepts derive from the conservation of energy and are applied in solving hyperstatic structures and in the Least Work method associated with Castigliano's theorems.
Participants express differing interpretations of the terms "strain energy" and "potential energy of loading," indicating that there is no consensus on their definitions or relationships.
There are unresolved definitions and relationships between strain energy and potential energy of loading, as well as assumptions regarding the context in which these terms are applied in engineering.
chandran
QUOTE:
POTENTIAL ENERGY OF AN ELASTIC BODY(example spring)=STRAIN ENERGY-POTENTIAL ENERGY OF LOADING
We all know that potential energy of a spring is equal to 0.5*k*x*x were x is the displacement in the spring and k is the spring constant. This is called STRAIN ENERGY.
What is the second term "POTENTIAL ENERGY OF LOADING" mean.
Only mass and elastic bodies can store energy. Why LOADING has POTENTIAL ENERGY?
Any examples?
I think you've got it backwards! I would say that the "1/2 k x2" IS the "potential energy of loading", that the "strain energy" is the energy that deforms the spring. Assuming that the deformation is not permanent then the potential energy of the spring is the strain energy PLUS then potential energy of loading.
No, the "strain energy" is [itex]1/2 k x^2[/itex]. The "potential energy of loading" is the work done by the loading force.
chandran: These concepts are used in engineering to analyze the elasticity of materials, crack formations, and lots more. You might get better answers if you asked these kind of questions in the engineering forums.
Like Doc Al explained it's basically a concept used in engineering which came of course from the Conservation of energy. It's main use it's in solving hyperstatic structures or statically undetermined structures, it has application in the Least Work method in use with Castigliano's theorems.
  • · Replies 54 ·
  • · Replies 20 ·
