Solving Isothermal Expansion of an Ideal Monatomic Gas
The discussion focuses on solving the isothermal expansion of an ideal monatomic gas, specifically addressing the equations governing pressure and temperature during the expansion from an initial state of V1 = 1 litre, P1 = 2 atm, and T1 = 300 K to a final state of V2 = 2 litres, P2 = 1 atm. Key equations derived include P(V) = -V + 3 for the pressure function during expansion. The user seeks clarification on calculating temperature at maximum volume (Tmax) and the associated work done, internal energy change, and heat transfer during the process. The discussion confirms that the problem does not involve adiabatic processes.
  • Understanding of ideal gas laws, specifically PV = nRT
  • Familiarity with isothermal processes and their characteristics
  • Knowledge of thermodynamic concepts such as work done and internal energy change
  • Ability to manipulate linear equations and slopes in the context of PV diagrams
  • Calculate the temperature function T(V) during the expansion using the ideal gas law
  • Determine the volume at which the temperature Tmax occurs and calculate Tmax
  • Compute the work done and change in internal energy for the isothermal process
  • Explore the efficiency of the process and its implications in thermodynamics
Students and professionals in thermodynamics, particularly those studying ideal gas behavior and isothermal processes, as well as anyone preparing for exams in physics or engineering disciplines.
ilovephysics
ok i really don't understand this question, especially about finding the functions for the recompressed isothermal and about the recompression stuff, I am just stuck
An ideal monatomic gas is expanded from initial volume V1 = 1 litre, P1 = 2atm, and T1 = 300K to a volume V2 = 2 litres, and P2 = 1atm. The expansion is performed along a straight line in the PV-diagram. It is then re-compressed isothermally to its original values. a) find the function P(V) describing the expansion b) find the function T(V) during the expansion c) at which volume is the temperature a maximum Tmax and what is the volume Vm at this maximium temperature Tmax? d) what is the work done, the change in internal energy and the heat taken in during the temperature increase T to Tmax? e) what are these values for the final part of the expansion Vm to V2? f) fint the efficiency
for the parts about work done and internal energy i think i know how to do those, by using formulas like dU=nCvdT, I am just not sure
also does this question have anything to do with adiabatic processes? i don't think it does...but correct me if I am wrong, thanks!
What parts of this problem have you attempted ? Please show your work first.
No, this question has nothing to do with adiabatic processes (but that should be for you to figure out).
k for part a i used p1, v1, v2, and p1, to find the slope which is rise/run and the slope is -1, i then plugged this into y=mx+b substituting p1 as y and v1 as x, and found b to be 3, so the equation i got is P(V) = -V + 3, which i don't know if its right or not..part b i have no idea how to do because i don't have T2 given so i can't find slope and do wht i did in part a, part c i tried to use pv=nrt and isolate T but I am stuck because i don't know the V at Tmax, and i don't know Tmax so i have 2 unkowns..and i think i could do parts d,e and f if i figure the rest out
