Rolling motion linear and translation equation
The discussion centers on the relationship between rolling motion and frictional forces, specifically addressing whether the frictional force during rolling is equivalent to static friction. It is established that during rolling without slipping, the point of contact is at rest, and thus the friction force corresponds to static friction. However, the maximum static friction force is defined as kN, where k is the coefficient of static friction. It is clarified that while friction acts during rolling motion, it does not perform work, as it does not act over a distance, thereby conserving energy.
  • Understanding of rolling motion dynamics
  • Knowledge of static friction and its coefficient
  • Familiarity with energy conservation principles in physics
  • Basic grasp of force equations in mechanics
  • Study the concept of rolling friction and its coefficient
  • Explore the principles of energy conservation in non-slip rolling scenarios
  • Learn about the differences between static and kinetic friction
  • Investigate the applications of friction in various mechanical systems
Physics students, mechanical engineers, and anyone interested in the mechanics of motion and frictional forces in rolling objects.
ambuj123
Hello
well i have a very basic doubt
well when we have a rolling motion
and surface is rough
then what i used to do was write linear and translation equation and find f (Frictional force)
Now is this frictional force same as static friction and can we write is as kmg where k is coeffecient of static friction assuming since point of contact is at rest so static friction acts.
Please help
further if friction acts during rolling motion we know energy remains conserved and no dissipation takes place but does that mean frictional force does no work
thanx
There's a different constant known as the coefficient of rolling friction, which is what you must apply.
http://webphysics.davidson.edu/faculty/dmb/PY430/Friction/rolling.html
During rolling without slipping, the point of contact is instantaneously at rest. So when an object rolls without slipping on a surface, the friction acting corresponds to static fricton.
Since the point of contact is instantaneously at rest, the friction force does not act over any distance and therefore does not change the total energy.
Also, the maximum possible force by static friction is given by kN. So, in most questions, where it is only mentioned that sufficient friction to prevent slipping exists, you can't use the static friction as kN.
  • · Replies 35 ·
  • · Replies 42 ·
  • · Replies 97 ·
