Energy of an Infinitely Rigid Object Impacting a Wall
  • Context: Graduate
  • Thread starter Thread starter haynewp
    Energy Wall
The discussion revolves around the hypothetical scenario of an infinitely rigid object impacting an infinitely rigid wall, exploring the implications for energy transfer and the nature of rigidity in physical models. Participants engage with concepts related to energy dissipation, sound, heat, and the limitations of the infinitely rigid model.
  • Some participants suggest that energy from the impact could manifest as sound or heat.
  • One participant proposes that less heat would be produced with ductile materials due to energy absorption in deformation, questioning the role of molecular interactions in heat generation.
  • Another participant argues that if the object is infinitely rigid, it would bounce off the wall without losing energy, maintaining its original speed and mass.
  • A participant challenges the utility of the "infinitely rigid" concept, questioning how such an object could respond to forces without deformation.
  • It is noted that the idea of an infinitely rigid rod has been linked to faster-than-light signaling, although this is acknowledged as a non-viable concept.
Participants express differing views on the implications of an infinitely rigid object, with no consensus on the nature of energy transfer or the validity of the infinitely rigid model.
Limitations include the ambiguous definition of "infinitely rigid" and the unresolved implications of such a model on physical interactions and energy transfer.
haynewp
If you had an infinitely rigid object and threw it against an infinitely rigid wall, where would the energy go?
I think it would go into that noise that just blew a hole in your ear drums. But this reminds me of something that I should post a thread about...
Is not sound kind of a form of organized heat? Oh what the heck, you're right, I should have said that...I'm getting forgetful.
So I guess less heat be produced with a ductile material than an extremely rigid one since some of the energy is absorbed in the deformation. But isn't it molecular interaction that is causing the heat anyway?
Why would the energy "go" anywhere?
"infinitely rigid" means "infinitely elastic" so that the infinitely rigid object would bounce of the infinitely rigid wall with its original speed and mass.
What exactly is meant by "infinitely rigid"? If you press against a solid object, it deforms just the right amount to press back. If it is very rigid, it deforms very little to give the force (effectively it has a high spring constant dF/dx). If it is infinitely rigid, it deforms not at all. So how does it "know" how much force to react with? It doesn't. I conclude that the "infinitely rigid" case is not a useful model of anything.
It has been said that an infinitely rigid rod could be used for faster than light signaling. Of course there is no such thing. Infinitely rigid implies infinite density and sound traveling through the object at an infinite speed.
Yeah, you're right. Tricky one.
  • · Replies 46 ·
  • · Replies 61 ·
12K
