Implicit and inverse function theorem
The discussion revolves around the implicit and inverse function theorems, focusing on their implications, proofs, and the conditions under which they hold. Participants explore concepts related to differentiability, determinants, and the relationships between these theorems in the context of mathematical analysis.
  • One participant questions how the determinant of the matrix of partial derivatives relates to the existence of local maxima or minima, suggesting a connection between the inverse function theorem and critical points.
  • Another participant proposes that understanding differential approximation could clarify the relationship between the two theorems, hinting at the importance of the rank of the derivative matrix.
  • There is a request for suggestions on proving that the implicit function theorem implies the inverse function theorem, indicating a desire for deeper understanding of the logical connections between these theorems.
  • A participant inquires about the necessity of the determinant of DF/DY being non-zero in the implicit function theorem, questioning the role of this condition in relation to the inverse function theorem.
  • One participant expresses confusion regarding the requirement for functions to be continuously differentiable in both theorems, prompting a suggestion to brainstorm counterexamples to explore this condition further.
  • Another participant reflects on their initial understanding of rank in linear algebra, emphasizing the importance of visualizing the image of a function near a point through differential approximations.
Participants express varying levels of understanding and familiarity with the theorems, and while some points are clarified, there remains uncertainty and a lack of consensus on several questions posed, particularly regarding the implications and proofs connecting the two theorems.
Some participants indicate that their understanding of the theorems is not fully developed, suggesting that there may be gaps in foundational knowledge or assumptions that could affect the discussion.
This discussion may be useful for students or individuals seeking to deepen their understanding of the implicit and inverse function theorems, particularly those grappling with the nuances of differentiability and the implications of these mathematical concepts.
calvino
Lately, we've been going over these two theorems in class. I have a few questions to put forth.
1) I know that in lower spaces, an inverse of a function exists locally (say around a point G) if it does not attain it's max/min at G (i.e. if f'(G) doesn't equal 0). Now, with the inverse function theorem, we have that det| Df | doesn't equal 0 (where Df is the matrix of partial derivatives?). I'm unsure how the determinant of the matrix relates to max/min at a point- So i can relate the two ideas.
2)I know that the inverse function theorem implies the implicit function theorem, and have seen proofs of it, but how can we prove that the implicit function theorem implies the inverse function theorem? (any suggestions on how to go about this proof would be appreciated)
3)In the implicit function theorem, where we consider a vector in R^m as [x y], x in R^(m-n), y in R^n, why is it that we only need the the determinant of DF/DY to not equal 0? Is this where the inverse function theorem comes in (to create a new function G s.t. G(x)=y?). What exactly is that matrix DF/DY? Also, why does there need exist a solution to the function?
4) In both theorems, why is it required to have f continuously differentiable?
Sorry if I'm asking too many questions, as I know some may flame me for this fact, but thanks in advance as any help is very appreciated.
For 1) and 3), when you have differentials, consider differential approximation!
[tex] f(x) \approx f(x_0) + (Df)(x_0) \cdot (x - x_0)[/tex]
Intuitively, this means that f looks like a linear function, if you zoom in far enough.
Or, if you like, you could only approximate on some variables:
[tex] f(x, y) \approx f(x_0, y) + L(x_0, y) \cdot (x - x_0)[/tex]
What ought L be?
So now, you have to apply your geometric insights! A very interesting number here is the rank of Df. (And you thought linear algebra didn't have any practical use!) If you knew the rank of Df at a point, (approximately) what can you say about the image of f near that point?
(I'll stop with this hint, to give you a chance to work it out)
In the case that Df is square, asking for a nonzero determinant is nothing more than asking for Df to be full rank.
Also, you should note that, in one dimension, f'(x) = 0 does not mean that f attains a local extremum at x.
For 2, I would see if I could write an implicit expression involving what ought to be the inverse of your function.
For 4, I would brainstorm for interesting functions that aren't continuously differentiable, and see if I could come up with a counterexample. Looking for places in the proof that use the continuity of the derivative might suggest ways you want your counterexample to behave.
Thanks for your help sir. You have cleared up a bit for me. However, I guess I'm not as well familiar with the topics as I should be, as most of what you talked about is confusing to me. Perhaps after I read up on both theorems a little more, I will get it. Nontheless, thanks a bunch, again.
I remember that when I came out of linear algebra, all "rank" meant to me was some useless number one could compute from a matrix!
Anyways, the important thing is to try and figure out what the image of the function looks like near a point by considering what the image of the differential approximation looks like.
