Measuring Decay Rate with Geiger Counter: Calculating Error and Seeking Input
  • Thread starter Thread starter nrm
    Probability
The discussion centers on calculating the error associated with measuring the decay rate of a radioactive sample using a Geiger counter. The user registered 100 decays over a 10-second interval and applied the formula for error, resulting in an error of approximately 0.316. The correct approach for standard deviation for the count rate is to use the formula sqrt(n)/t, where n is the count and t is the measurement time. This clarification highlights the importance of distinguishing between standard deviation for count and count rate in radioactive decay measurements.
  • Understanding of radioactive decay principles
  • Familiarity with Geiger counters and their operation
  • Knowledge of statistical error analysis
  • Basic proficiency in mathematical formulas related to standard deviation
  • Study the application of the formula sqrt(n)/t for count rate standard deviation
  • Explore advanced statistical methods for error analysis in radioactive measurements
  • Learn about different types of radiation detectors and their measurement techniques
  • Investigate the implications of error in experimental physics and its impact on results
Physicists, radiation safety professionals, students in nuclear science, and anyone involved in experimental measurements of radioactive decay.
nrm
I was hoping that somebody would check my work. Any input is appreciated.
A decay rate of a radioactive sample is being measured using a Geiger counter. During a 10 second measurement 100 decays are registered.
what is the error associated with the result?
[tex]\sigma_{y} = \frac{\sigma}{\sqrt{N}}[/tex]
My work:
[tex]\sigma^2 = np = (100)(1/10) = 10[/tex]
so [tex]\sigma = \sqrt{10}[/tex]
putting this into the previous equation where I make N=100 I get an error around 0.316. Did I do that right?
If you are loking for the standard deviation for the count rate, then your correct equation should be sqrt(n)/t where n is your count and t is the count time. If you are looking for the standard deviation for the count, then it's just sqrt (n).
  • · Replies 99 ·
  • · Replies 26 ·
12K
