Magnetic Field and Electric field outside a long solenoid
The discussion revolves around the induced electric field generated by a long solenoid carrying a time-varying current. The problem specifically asks for the electric field at points inside and outside the solenoid, given its parameters such as turns per unit length and radius.
  • Participants discuss the application of Faraday's Law to derive the induced electric field both inside and outside the solenoid. There is a focus on the relationship between magnetic flux and electric field, particularly questioning why an electric field exists outside the solenoid despite the absence of a magnetic field in that region.
Some participants have provided calculations for the induced electric field in both regions, while others are exploring the conceptual underpinnings of the problem. There is an ongoing dialogue about the implications of changing magnetic flux and its relation to electric fields, with no explicit consensus reached on all points raised.
Participants are navigating assumptions about the behavior of electric and magnetic fields, particularly in relation to the solenoid's geometry and the nature of induced fields. There is also mention of textbook references, indicating that the problem is derived from standard educational materials.
darkar
Hello,
The question goes like this:
A long solenoid has n turns per unit length and carries a current given by I=I₀sinωt. The solenoid has a circular cross section of radius R. Find the induced electric field at a radios r from the axis of the solenoid for (a) r<R (b) r>R
Well, i got the first part as E=μR²N²ωI₀cos(ωt)/(2Rl). Does this looks like it?
For the second bit, i found it as zero. But i am not really sure. And if it is zero, What should i say?
Hello there,
You'll have to excuse me because I'm not using the greek symbols.
(a) r<R,
int(E.dl)=-d(B.Area)/dt (definition of induced emf) take loop around
E.2*pi*r = -pi*(r^2)*mu*n*I*omega*cos(omega*t)
E= -(mu*n*I*omega*r*cos(omega*t))/2
is the induced field inside solenoid. Your answer is close but use r instead of R (since we are inside).
(b) r>R, outside
You are confusing with the case when magnetic field is zero outside long solenoid due to cancellations between field due to currents in successive & opposite loops.
In this case, (r>R...remember loop is longer)
E*2*pi*r = -pi*(R^2)*mu*n*I*omega*cos(omega*t)
(remember flux is over an area defined by pi*(R^2))
E = -(mu*n*I*omega*(R^2)*cos(omega*t))/ (2*r)
is the induced electric field outside.Hope that helps,
Rama
Are you sure they are asking about Electric fields? That doesn't make much sense. More often, you will be asked to solve for the magnetic field as a function of radius for the solenoid...
Yea, i m asked to find electric field. And i just found out this is one of the question found from the textbook. And yes, that's the correct answers! but i am still not sure why it is not zero. isn't that when there's no magnetic field, there's no electric field as well?
darkar,
To understand why there is an electric field outside the solenoid, just think about Faraday's Law. If you draw a loop around the solenoid, the magnetic flux through the loop is changing as a function of time, right? Even though there is no magnetic field outside the solenoid there is still a changing magnetic flux (from the field inside the solenoid). What does this tell you about the electric field?
Yea, that's amaze me. Why can there be magnetic flux but no magnetic field. So lif there's magnetic field, the magnetic flux is constant?
  • · Replies 33 ·
  • · Replies 20 ·
