Orbital simulator and non fixed orbit
The discussion focuses on a three-planet system simulation where Planet 1 is a fixed, massive body, while Planets 2 and 3 exhibit varying orbits. The gravitational interactions between these planets lead to non-fixed orbits for Planet 2, despite its initial placement in an elliptic orbit. The equations governing the system, specifically mP2 * aP2 = - FP3 - FP1, illustrate the influence of gravitational forces on the motion of the planets. The unexpected variations in Planet 2's orbit are attributed to the gravitational pull from the other planets in the system.
  • Understanding of Newton's laws of motion
  • Familiarity with gravitational force calculations
  • Knowledge of orbital mechanics and elliptical orbits
  • Experience with simulation programming for celestial mechanics
  • Research gravitational force calculations in multi-body systems
  • Explore numerical methods for simulating celestial mechanics
  • Learn about perturbation theory in orbital dynamics
  • Investigate the effects of mass ratios on orbital stability
Astronomers, astrophysicists, and simulation developers interested in celestial mechanics and orbital dynamics will benefit from this discussion.
FLOUR
Hello,
Let's consider a small 3 planet system. One of the planet's is fixed and is a lot heavier than the others. The acelleration is
From with the velocity is derived with allows to calculate the positions of the planet's in a simulator program. After running the simulation, The orbit of one of the "moving" planets isn't fixed - some variation occur after each loop.
What can cause this? The other planet (that's not fixed) has an elliptic fixed orbit.
FP = Gravitational Force of Planet
Thanks.
Hello,
some more data about the situation:
Planet 1 - fixed on the center of the referential
Planet 2 - initial distance = 3 AU (start_x= 3 AU, start_y = 0)
Planet 3 - initial distance = 6 AU (start_x= 6 AU, start_y=0)
So Planet 2 is on the "middle" of the system.
Planet 1 is about 1000 times "heavier" than Planet 2.
Planet 3 is about 30 times "heavier" than Planet 2.
Planet 3's orbit is fixed elliptic. Planet 2's orbit has some variation to the initial elliptic orbit.
1) I was under the impression that orbits were suposed to be fixed...
2) I'm guessing the planet in the "middle" is getting heavy interaction from the other planet's...
Thanks for your comments.
  • · Replies 21 ·
