Kepler's Laws - implications of changed theory
  • Thread starter Thread starter Bonulo
    Laws Theory
The discussion focuses on the implications of changing the gravitational force from being inversely proportional to r² to r³ on Kepler's Laws. Kepler's 1st Law is altered as planets would experience less acceleration towards the sun, potentially leading to larger orbits or escape from their current orbits. Kepler's 2nd Law remains difficult to determine due to the conservation of angular momentum, while Kepler's 3rd Law changes to reflect that the orbital period becomes proportional to the 5/2 power of the major axis length, rather than the traditional 3/2 power.
  • Understanding of Kepler's Laws of planetary motion
  • Basic knowledge of gravitational force laws
  • Familiarity with Newton's 2nd Law of motion
  • Concept of angular momentum conservation
  • Research the mathematical derivation of Kepler's Laws under different gravitational models
  • Explore the implications of non-closed orbits in celestial mechanics
  • Study the conservation of angular momentum in varying force fields
  • Investigate the historical context and development of gravitational theories
Astronomers, physicists, and students of celestial mechanics seeking to understand the effects of altered gravitational laws on planetary motion.
Bonulo
I've been presented with the following problem:
[itex]Problem[/itex]: As a thought experiment it's presumed that the attracting force of gravitation instead of being inversely proportional to [itex]r^2[/itex], is inversely proportional to [itex]r^3[/itex]. How does this theory change Kepler's 3 laws?
(For one of the laws it isn't easy to determine, so a "Can't easily be determined" is an acceptable answer.)
a) How is Kepler's 1st law changed?
b) How is Kepler's 2nd law changed?
c) How is Kepler's 3rd law for cirkular planetary orbits changed?
I'm merely looking for a few hints. I assume it to be implicit that no advanced equation juggling will be needed (the topic is, accordingly, treated like this in the textbook too).
a) Kepler's 1st law.
"Each planet moves in an elliptical orbit, with the sun at one focus of the ellipse."
Applying the theory will make a given planet accelerate less towards the sun, thus changing its orbit. Its period of orbit will drop. It might settle itself in an orbit with larger axes, or continue spiraling outwards - eventually escaping the orbit - since the escape speed will be smaller (due to its relation with [itex]G[/itex]).
b) Kepler's 2nd Law
"A line from the sun to a given planet sweeps out equal areas in equal times."
This law doesn't, like the 1st and 3rd, in reality, work only for a [itex]1/r^2[/itex] force. That might hint to the conclusion that this is the law whose change isn't easy to determine. Irrespectively - it seems a bit hard. Unless some analysis of the [itex]dA/dt[/itex] and angular momentum, if e.g. the angular momentum [itex]L[/itex] isn't constant anymore.
c) Kepler's 3rd Law
"The periods of the planets are proportional to the 3/2 powers of the major axis lengths of their orbits."
Newton's 2nd Law gives, for the radial speed, [itex]v=\sqrt{(G*m_E)/r}[/itex], which with the theory must be changed to [itex]v=\sqrt{(G*m_E)/r^2}[/itex], thus making the period [itex]T[/itex] larger - so that it's proportional to (3/2+1) = 5/2 powers of the major axis length: [itex]T=(2*\pi*r^{3/2})/\sqrt{G*m_e}[/itex], because of the relation [itex]T=(2*/pi*r)/v[/itex].
How much of this is on the right track?
b) Kepler's 2nd Law
c) Kepler's 3rd Law
Newton's 2nd Law gives, for the radial speed, [itex]v=/sqrt((G*m_E)/r)[/itex], which with the theory must be changed to [itex]v=sqrt((G*m_E)/r^2)[/itex], thus making the period [itex]T[/itex] larger - so that it's proportional til (3/2+1) = 5/2 powers of the major axis length: [itex]T=(2*/pi*r^(3/2))/sqrt(G*m_e)[/itex], because of the relation [itex]T=(2*/pi*r)/v[/itex].
1. An additional possibility is that it will orbit, but the orbit won't be closed. The orbit would look like something you get off a spirograph, if you're old enough to know what one of those is! (I don't think they make them anymore, do they?)
2. Regardless of the power of the force law, the angular momentum is still conserved.
3. I glanced over this and everything looks okay. Again, in reference to my comment on 1, the orbit may not be closed so talking about the period of motion may not make sense.
Hope it helps, rather than confuses! :wink:
-Dan
Guesses at answers
-Dan
Thanks for the quick reply!
I'm prone to thinking that the answer in 1) is a spiralling orbit, which would make 2) the hard-to-determine-one (since the type of orbit would be hard to determine). However, if the orbit isn't closed, it might be 3) that's hard to determine, since it only deals with a period.
So either:
Answer I -
  1. The orbit's some kind of spiral, and thus not a closed orbit
  2. This is hard to determine, because it's hard to determine how [itex]dA/dt changes with changes in radius[/itex]
  3. ?
Answer II -
  1. The orbit's closed, but larger than before
  2. Hard to determine.
  3. The period is now related to 5/2 powers of the radius (instead of 3/2).
It seems, though, that nr. 2 in Answer II wouldn't be hard to determine (maybe nr. 1 will be instead).
  • · Replies 18 ·
  • · Replies 23 ·
