Electric Field due to a line of charge
The discussion revolves around calculating the electric field due to a straight line segment of length L with a uniform line charge density, λ. Participants are exploring the behavior of the electric field at a distance z from one end of the line segment and questioning the implications of the limit where z is much greater than L.
  • The original poster attempts to derive the electric field components in both the x and z directions and questions the behavior of the electric field as z approaches infinity. Some participants discuss the implications of the electric field approaching zero and the conditions under which this occurs.
Participants are actively engaging with the problem, offering insights into the calculations and exploring the behavior of the electric field in different limits. There is a recognition of the need to clarify the relationship between the electric field and the potential, as well as the conditions under which certain components may vanish.
Some participants note potential discrepancies in the calculations and the assumptions made regarding the electric field's behavior at large distances. There is also mention of references to Griffiths' textbook, indicating a shared resource for understanding the concepts involved.
stunner5000pt
Have a look at the diagram
Find the elctric field a distance z above one end of a astraight line segment of length L which carries uniform line charge lambda. Check that your formula is consistent with what you would expect for the case z >> L
SOlution:
[tex]\lambda= q/L[/tex]
[tex]dq = \lambda dx[/tex]
For the electric Field in the horizontal (points to the left and is negative)
[tex]dE_{x} = \frac{1}{4 \pi \epsilon_{0}} \frac{dq}{(z^2 + x^2)} \sin \theta[/tex]
Subsituting what we know about sin theta and dq
[tex]dE_{x} = \frac{1}{4 \pi \epsilon_{0}} \frac{\lambda dx}{(z^2 + x^2)} \frac{x}{\sqrt{z^2 + x^2}}[/tex]
integrating x = 0 to x = L
[tex]E_{x} = \int dE_{x} = \frac{\lambda}{4 \pi \epsilon_{0}} \int_{x=0}^{x=L} \frac{xdx}{(z^2+x^2)^{\frac{3}{2}}} = \frac{\lambda}{4 \pi \epsilon_{0}} \left[ \frac{-1}{\sqrt{z^2 + x^2}} \right]_{x=0}^{x=L} = \frac{\lambda}{4 \pi \epsilon_{0}} \left[ \frac{-1}{\sqrt{z^2 + L^2}} + \frac{1}{z} \right][/tex]
[tex]E_{x} = \frac{\lambda}{4 \pi \epsilon_{0}} \left[ \frac{1}{z} -\frac{1}{\sqrt{z^2 + L^2}} \right][/tex]
ok so suppose z >> L then the electric field is zero?? Shouldnt it reduce to that of a point charge and not zero?? this should be regardless of whether i solve for x or z right??
for the Z direction i got
[tex]E_{z} = \frac{\lambda}{4 \pi \epsilon_{0}z} \frac{L}{\sqrt{L^2 + z^2}}[/tex]
unlike the last one this one does reduce to the equatiopn for a point charge but is off my a factor of 1/z ...
combining the two yields
[tex]\vec{E} = \frac{\lambda}{4 \pi \epsilon_{0}} \left[ \frac{1}{z} -\frac{1}{\sqrt{z^2 + L^2}} \right] \hat{x} + \frac{\lambda}{4 \pi \epsilon_{0}z} \frac{L}{\sqrt{L^2 + z^2}} \hat{z}[/tex]is there soemthing wrong with the calculationg ofr hte X Horizontal Direction?? Please help
Thank you in advance for your help and advice!
If you get far enough away, the field from anything (finite) goes to zero! :wink: But you need to understand how it approaches zero. In this case, think about it: You are very far from a point charge--What's the direction of the field?
It's not off. You just need to examine its behavior as z goes to infinity. Use a binomial expansion:
[tex](L^2 + z^2)^{-1/2} \approx (1/z)(1 - \frac{L^2}{2z^2})[/tex]
I'm studying from Griffiths too :) and I've a question about this exercize.
The electric potential:
[tex]V = \frac{ \lambda }{4\epsilon_0 \pi} ln\left(\frac{L+\sqrt{z^2+L^2}}{z}\right)[/tex]
Calculating the electric field from the V's gradient, it has x component always at zero.
Where the problem?
I'm sorry for my poor english, good evening mate!
Yeah, Griffith's book is good.
From your calculation for [tex]\vec{E}[/tex] (yes i think it's correct for both direction), for z >> L, the electric field of component - x will disappear (since [tex]\frac{1}{z} - \frac{1}{z} = 0)[/tex] and leaves for us the z - component as below:
after simplifying, [tex]\vec{E} = \frac{\lambda L}{4 \pi \epsilon_{0}z^2}\hat{z}[/tex] for z>>L.
the case is the same as above example from griffith's book (that is for E at a distance z above midpoint of line L). I quoted it : From far away the line
"looks" like a point charge [tex]q = 2\lambda L[/tex].
Where the problem?
I think x and y component will be gone since you do grad [tex]\nabla[/tex]-operation to potential (the potential only depend on z). so,
[tex]\vec{E} = -\nabla V = -\frac{\lambda}{4\pi \epsilon_{0}}\frac{\partial}{\partial z}\ln (\frac{L + \sqrt{z^2 + L^2}}{z})[/tex].
suppose [tex]k = \sqrt{z^2 + L^2}[/tex],
it will give [tex]\vec{E} = \frac{\lambda}{4 \pi \epsilon_{0}}(\frac{z}{k(L + k)} - \frac{1}{z})\hat{z}[/tex]
btw, i can't find this problem in griffith's book...
  • · Replies 19 ·
  • · Replies 0 ·
