Thread Closed
plutonium production
Share Thread Thread Tools
Dec15-03, 09:52 AM   #1
i m a newbie in nuclear field. i m just wondering how difficult plutonium is produced? is it that u just irradiate U-238 with a neutron and u will get a Pu-239? is there any constraint or technical difficulty for that?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec15-03, 12:04 PM   #2
Mentor
Well, the difficulty is in that you have to do it inside a nuclear reactor. Then you have to separate out the Pu.
Dec15-03, 01:10 PM   #3
actually i was given a question that sound like this.
using a portable neutron generator which generates 14 MeV neutrons at 1 * 10^12 neutrons/second via the D-T fusion reaction, how long does it take to produce 20kg of Pu-239?
I am just wondering is that possible?
Dec15-03, 07:09 PM   #4
Recognitions:
A major unknown in the problem you stated is how much U238 do you have and its geometry with respect to the neutron source. Also are there other materials present which could absorb some of the neutrons? To give you a start use Avogadros no. (approx 6x1023) to get the number of atoms in 238 grams of U238.
Dec15-03, 07:15 PM   #5
thank you mathman.
the quantity of U-238 is not given, i was only asked how long will it take to produce 20-kg of Pu-239. based on the equation
U-238 + n -> U-239 -> Np-239 -> Pu-239
i interpreted it as one mole of U-238 when irradiated by 1 neutron will produce one mole of Pu-239. And so, to produce 20kg of Pu-239 (5.04*10^25) u will need 5.04*10^25 of U-238. Is that thought correct here?
please help. thanks.
Dec15-03, 07:17 PM   #6
oops sorry, i forgot to mention just now.
i was asked to approach this problem based on the assumption that all neutron is absorbed in the fertile material. so i guess there should be no other material which will absorb the neutron.
of course i can be wrong. i m just a newbie.
Dec15-03, 08:32 PM   #7
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
I'm going to merge this thread with the identical one in homework help.
nuclear,
If you're going with the assumption that every neutron produced is involved in the reaction, then this problem is really just plug and chug.
You know how much Plutonium you need to produce, so with Avogadro's number and the mass, you can get the total number of neutrons required.
Once you have that number, you use the rate to determine the time it took to get them.
Does that help any?
Thread Closed
Thread Tools
Similar Threads for: plutonium production
Thread Forum Replies
Plutonium reactor Nuclear Engineering 2
How do you get Plutonium from Uranium? High Energy, Nuclear, Particle Physics 2
plutonium Introductory Physics Homework 3
plutonium Introductory Physics Homework 1
plutonium calculation Introductory Physics Homework 0
