A matrix satisfies A^2 - 4A + 5I = 0, then n is even.
  • Thread starter Thread starter Hydroxide
    even Matrix
The discussion revolves around two problems involving matrices. The first problem asks to show that if a matrix \( A \) satisfies the equation \( A^2 - 4A + 5I = 0 \), then the dimension \( n \) of the matrix must be even. The second problem involves an \( m \times n \) matrix \( A \) where \( m < n \) and requires showing that the determinant of \( A^T A \) is zero.
  • Participants explore the implications of the equation \( (A-2I)^2 + I = 0 \) and discuss the properties of minimal and characteristic polynomials. There is also a focus on the relationships between rank, invertibility, and determinants in the context of the second problem.
Some participants have made progress on the first question, indicating a clearer understanding, while others are still grappling with the second question. Guidance has been offered regarding the relationships between matrix properties, but there is no explicit consensus on the second problem yet.
There is a mention of the matrix \( A \) potentially having complex entries, which raises questions about the assumptions being made. Additionally, some participants note that they have not yet covered the concept of rank, which may affect their ability to engage with the second problem fully.
Hydroxide
1) Let A be an n x n matrix with A^2 -4A +5I = 0. Show that n must be even.
2) Let A be an m x n matrix where m<n. Show that det(AT x A) = 0
1) (A-2I)^2 +I=0
Not sure what to do after this though
Thanks in advance
An n x n matrix with real entries? If it can have complex entries, this isn't true. Anyways, what do you know about minimal polynomials and characteristic polynomials?
2) Let A be an m x n matrix where m<n. Show that det(A^T x A) = 0
What do you know about the relationships between rank, invertibility, and determinants.
1) (A-2I)^2 +I=0
Okay, that's not bad. So (A-2I)2 = -I. Compute the determinant of both sides.
Cheers I've got the first question now. Was easier than i thought.
I still can't do 2) though.
Could you explain further please?
What are the dimensions of the matrix ATA? What can you say about the rank of ATA?
ATA is n x n
We haven't covered ranks yet
I know that ATA can reduced so that it has one row of zero's hence det=0. But I don't know how to show it in general.
It may help to think of matrix multiplication with a vector as a linear combination of the columns of the matrix
i.e. For [tex]A\vec{c} = \vec{b}\\[/tex] b is a linear combination of the columns of A
And hence a matrix multiplication with a vector will produce a matrix whose columns are a linear combination of the columns of the first matrix.
i.e. For [tex]AB = C\\[/tex] C's columns are linear combinations of the columns of A
Sorry if the Latex is less than desirable, as you can see, I'm new here.
