Would measures like skewness or kurtosis magnify uncertainty?
  • Context: Graduate
  • Thread starter Thread starter JoAuSc
    Uncertainty
The discussion revolves around the implications of using statistical measures such as skewness and kurtosis in the context of survey data that captures opinions on technology significance. Participants explore how these measures might affect the uncertainty of the results, particularly when considering measurement errors and the discrete nature of survey responses.
  • Some participants question whether skewness and kurtosis would magnify uncertainty in survey results, particularly when the data is subject to measurement error.
  • There is a discussion about the nature of uncertainty, with some suggesting that the distribution of errors (e.g., significant vs. slight errors) should influence the definition of uncertainty.
  • One participant proposes that if the additional uncertainty remains within a certain range, increasing the power in calculations might reduce its effect rather than increase it.
  • Concerns are raised about the validity of assigning numeric values to qualitative opinions, questioning the appropriateness of the scale used in the survey.
  • Participants discuss the implications of rounding and interpretation errors on the observed data, suggesting that these factors may not significantly skew the results relative to true responses.
  • There are suggestions to run simulations to compare true responses with observed responses to better understand the effects of measurement errors.
Participants express differing views on the impact of skewness and kurtosis on uncertainty, and there is no consensus on whether these measures are useful in the context discussed. The conversation remains unresolved regarding the best approach to quantify uncertainty in this scenario.
Limitations include the dependence on how true responses are distributed relative to observed responses and the unresolved nature of the mathematical implications of using higher moments in the presence of measurement errors.
JoAuSc
Let's say you've given out surveys where people have to respond whether they think the technology is "not significant/little significance/moderately significant/..." so that there are six choices total, on a scale from 1 to 6. After collect a few dozen or so of these surveys you get a distribution.
Obviously, there's a large amount of uncertainty in the measurement, probably around + or -1. If you try and take statistical measures such as the skewness or kurtosis, which involve cubing or taking the fourth power of the deviations from the mean, would that magnify the resulting uncertainty to the point where these measures would be unusuable?
That depends on your objective. When defining uncertainty, do you think that "a few people erring significantly" tells you more about the extent of the uncertainty than "a lot of people erring slightly"? Then, skewness and kurtosis should be part of your definition. (I do not fully understand when you say "they magnify uncertainty." Do you have in mind some kind of additive uncertainty function which adds together the 2nd through the 4th moments, unweighted?) Another issue is whether we are talking about the uncertainty of x (usu. measured as standard deviation = s), or the uncertainty of "x bar" (usu. measured as standard error = s/√n)? If the latter, then each additional moment will have to be weighted by a function of the sample size.
Let me try to clarify. When people are polled, if their opinions are measured exactly, then there should be a certain spread of data. In addition, there's uncertainty in that 1.) people must choose from six discrete data points rather than a continuum, and 2.) that people may not agree on whether a certain view of the future is "moderately significant" or "slightly significant", even if they agree exactly on the specific forecast. I'm guessing the additional uncertainty (that is, in addition to the natural spread of opinion) is about plus or minus one. I'm also guessing that everyone's slight uncertainty is more important than a few people's out-of-the-ballpark guesses. Thus, according to what you said, skewness and kurtosis would not be necessary; however, I'm trying to analyze the natural spread, not the uncertainties I just mentioned. My question is that in the process of calculating skewness, kurtosis, etc., would the additional errors propagate themselves enough so that the end result is too uncertain to be useful?
The technical terms for the problem(s) you described is measurement error, or errors-in-variable.
Let's take each of the problems in turn. For the "rounding problem," suppose 20 people circled option 2. In reality, they might be distributed uniformly from 1.5 to 2.4 with an increment of 0.1. Under this assumption, the observed responses aren't going to be especially skewed or kurtic relative to the true responses, even though they have a lower variance.
For the "interpretation problem" (I'll rename this the "trembling hand problem") suppose that 5 of the 20 people who circled "2" meant to circle "1" while another 5 meant to circle "3" but they all ended up circling 2 because "their hands trembled." (Is this a fair interpretation of your description?) For this problem, too, the observed responses aren't going to be especially skewed or kurtic relative to the true responses, even though they have a lower variance.
What is important is how you think the true responses are distributed relative to the observed ones. If the true responses are more or less evenly distributed with respect to the observed ones, then they are not going to make much of a difference for the moments greater than the 2nd.
Finally, you can easily run some simulations in Excel, and use the "SKEW" and the "KURT" functions to compare "true" responses with "observed" responses (of hypothetical respondents).
From a purely technical point of view, as long as the additional uncertainty is between -1 and +1, shouldn't increasing the power term reduce, not increase, its effect?
Of course the idea that assigning numeric values to opinions is utterly flawed in the first place. Why 1-6 for the 6 choices? Why not 1,2,4,6,7,8 as the values?
I think it's a good way of thinking about it, though it's more of a trembling-mind problem. For this problem, too, the observed responses aren't going to be especially skewed or kurtic relative to the true responses, even though they have a lower variance.
Thanks. I'll try that.
That's a good point. (I don't really have a choice in the matter, it wasn't my team that took the data, but I'll try to address this anyway.) I wouldn't say "utterly flawed", because it's obvious we can order the responses like we can order numbers, i.e. there's probably some kind of 1D continuum when it comes to the answer to "how significant would a breakthrough in solar sails be?", at least if we defined "breakthrough" definitely enough. FYI, here's an example of the key which was on the survey:
significance:
1- trivial
2 - marginal significance
3 - small significance
4 - moderate significance
5 - major significance
6 - revolutionary
Nevertheless, I agree that there's no good reason that (small - marginal) should equal (marginal - trivial), for example. We don't know how large the distances between successive data values is, so we can't do reliable math on this set, making figures such as the mean and the standard deviation (as well as the skewness and the kurtosis) less meaningful.
Perhaps I'm looking at analyzing this data the wrong way. I'd rather not do just the median and mode, since those indicators don't take into account most of the data values, but maybe something like quantiles. Let me know if you guys have any further ideas.
Thanks for the help. Looking at one of the wikipedia articles EnumaElish posted, I saw a paper mentioed called "On The Statistical Treatment of Football Numbers", which lead me to an old book called "Readings in Statistics", which had a lot of helpful information on this sort of stuff. Interestingly, a paper in there by C. Alan Boneau claims that, assuming you can definitely match a number to an opinion without having to make comparisons, then you can compare two populations with some altered variable by comparing their means, std. dev.'s, etc. In other words, sometimes calculating the mean of ordinal numbers is helpful. I don't know if it's legitimate enough in our case, but at least there's some evidence on our side.
My project partner and I plan to take the mean, std. dev., skewness, median, mode, and the absolute deviation from the scores we ourselves get from filling out the survey. As much as I want to try some methods more appropriate to ordinal data, we're trying to get this thing done by Thursday, so we don't really have time.
This prompted me to read Section 7.4 "Ordered Responses" in K. E. Train's book Discrete Choice Methods with Simulation.1 Suppose the respondents' answers are based on how much income (or utility, or "progress"), denoted Y, he or she expects to get out of the technological innovation that is being surveyed. The standard assumption in a discrete choice model would be to assume that the respondent will choose k'th response if yk < Y < yk+1, where y1, ..., yn+1 are the cutoff values of Y for n choices. Which leads me to think that as long as the cutoff values are well-specified (even if only conceptually), the ordinal (i.e. the nominal) values of the responses do not matter. That is, the underlying "latent" distribution of the Y's (predicted from or "fitted to" the observed responses) will be independent of the nominal values of the responses.
To be even more concrete, suppose 10 people out of 100 replied "third highest response". Then Prob(y3 < Y < y4) = 0.1. The nominal value of the "third highest response" does not matter.
1See Multinomial logit .
  • · Replies 0 ·
