| Thread Closed |
electric field problems |
Share Thread | Thread Tools |
| Jan24-04, 02:44 PM | #1 |
Here an electric field problems I'm struggling with:
Positive charge Q is uniformly distributed around a semicircle of radius a. Find the electric field at the center of curvature P. Answer in terms of Q, k, and a. When I worked this out on my own, I calculated the magnitude of the electric field to be (2Qk)/(a^2), but this is wrong. Could someone give me a hint on how to do this correctly? Thanks! |
| Jan24-04, 03:11 PM | #2 |
Mentor
Find the field for a segment (dΘ) of the semi-circle and integrate. Luckily it's an easy integral to do (since the distance is the same for all points on the curve). Try and set it up.
| Jan24-04, 03:11 PM | #3 |
Use symmetry
Consider an axis passing through the Centre and dividing the semicircle into two halves So charge density(lambda)=Q/(pi)r. Now consider dq charge symmetrical to axis u will see one component of Field produced cancels and other adds up in one direction. Can u show what u get from above hint Anyway it is going to be moved to HW |
| Jan24-04, 03:46 PM | #4 |
Does mean dE=(kdQ)/(a^2)?
dQ=Pi(a)(lamda) da? Is this remotely close? |
| Jan24-04, 04:02 PM | #5 |
Mentor
[tex]dE = \frac {k}{a^2} \sin \Theta dQ = \frac{Qk}{\pi a^2} \sin \Theta d\Theta [/tex] I did neglect to mention, as himanshu points out, that you will need to take advantage of symmetry. Imagine the semicircle intersecting points (-a,0) (0,a) and (a,0). The only component of field you need to worry about is the y-component: by symmetry, the x-components (from opposite sides) cancel. |
| Jan24-04, 04:13 PM | #6 |
I get (Qk)/(Pi a^2) directed down?
Thank you so much for helping me! |
| Jan24-04, 08:09 PM | #7 |
Mentor
| Jan25-04, 01:57 AM | #8 |
Yes u are off by a factor 2
| Thread Closed |
| Thread Tools | |
Similar Threads for: electric field problems
| Thread | Forum | Replies | ||
| Problems with Electric Field questions | Introductory Physics Homework | 3 | ||
| Electric Field Problems | Introductory Physics Homework | 3 | ||
| some problems..(electric field.electric potential) | Introductory Physics Homework | 3 | ||
| Help with electric field problems | Introductory Physics Homework | 2 | ||
| electric field problems... literally | Introductory Physics Homework | 3 | ||
