Is zero considered a number in mathematics?
  • Context: High School
  • Thread starter Thread starter hamlet69
    Count Zero
The discussion centers around the question of whether zero is considered a number in mathematics. Participants explore various definitions, properties, and implications of zero across different mathematical contexts, including arithmetic, set theory, and complex numbers.
  • Some participants assert that zero is a number, citing its role as the cardinality of the empty set and the additive identity.
  • Others highlight zero's unique properties, such as being the only solution to the equation x = -x and its significance in limits of positive and negative numbers.
  • A participant mentions the historical transfer of the concept of zero from India to the Arab world and its metaphysical interpretations.
  • There are discussions about zero's role in modular arithmetic, particularly mod 2, and how it interacts with other numbers like i and π.
  • Some participants express confusion about the implications of zero in different mathematical systems, particularly regarding the definitions of imaginary and irrational numbers.
  • One participant references a monograph by Richard Dedekind, raising philosophical questions about the nature of numbers.
  • Technical discussions arise regarding the algebraic properties of zero and its relationships in various fields, including extensions of finite fields.
Participants do not reach a consensus on the nature of zero as a number. While some agree on its mathematical significance, others raise questions about its role in different contexts, leading to multiple competing views.
The discussion includes various assumptions about mathematical definitions and contexts, particularly regarding modular arithmetic and the nature of complex numbers. Some participants express uncertainty about these concepts, indicating a lack of resolution on certain mathematical points.
This discussion may be of interest to those exploring foundational concepts in mathematics, particularly in relation to the number zero, its properties, and its implications in various mathematical frameworks.
  • #31
Originally posted by turin
I don't see how this could be nonsensible. It is a definition, and I don't see how it could be self-contradictory in this case. I'm assuming we already take for granted what ^2, +, 1, and "root" mean? Then, we just introduce another entry into our dictionary: i. What could be wrong with that?
try to declare j a root of [itex]e^x=0[/itex] over the reals. you won't get a field.
so that is why it is noteworthy that you can do this for algebraic equations, like [itex]x^2=-1[/itex]
  • #32
Originally posted by matt grime
f Just like in the real/complex case, we simply define A to be a root of this polynomial (the other root is 1+A), then there is an extension F_2[A] which we call F_4, it is the field with 4 elements, it is still not posible to find roots of every polynomial in F_4, so we can extend again and again. Each extension has 2^r elements for some r. The 'limit' of this construction, we'll call F, and it is the algebraic closure of F_2. It is infinite.
what is this field F? i am unfamiliar with the algebraic closure of a finite field. does it have a name? does it depend on which finite field we start with? (i am pretty sure that the answer to this is "yes") is there a nice way to write a generic element?
  • #33
Originally posted by Hurkyl
The proof that [itex]x^2 - 1[/itex] has only two roots (1 and -1) depends on the fact that you're working over a field; that is division always works (for nonzero things). When I introduced this new thing, [itex]h[/itex], we are no longer working over a field, so this proof fails.
What does it mean to be "working over a field?" I thought that the coefficients of the polynomial had to be members of a field.
Basically, I'm suggesting you do the same thing with these numbers. Just like you use the fact [itex]i^2 = -1[/itex] to simplify the expressions for ordinary complex numbers, you can use the fact [itex]\alpha^2 = 2\alpha - 2[/itex] to simplify expressions for complex numbers written in this new way.
I get it. That's kind of interesting.
... the Riemann Sphere ... extends the complex plane to include a point at infinity, but this is basic algebra here so we don't touch it.
Does one need the Riemann sphere to define 0 as a member of C?
... take the integers mod 8, ... here ... we say 4 and 2 are divisors of zero. This is not a good place to do arithmetic - we can't divide.
How can we have divisors without being able to divide? What is this new (to me) definition of divisor? Why do you only list 4 and 2? I thought that 0/anything = 0. Is it that 0/2 = 4 and 0/4 = 2? Is that true? If so, that's weird.
... {p} is the set of all multiples of p, that is all polynomials of the form p(x)q(x) for some omthe poly q(x).
What is a "omthe poly?"
This irreducibility means that when we form the mod p analogue for polynomials - ie two polys r and s are defined to be equivalent if p divides r-s, or equivalently there is another poly h with r = s+h*p -- that we get a field.
When we say "divide," do we always assume that there is no remainder? So, basically, by saying "p divides r-s," that is another way of saying that "p is a factor of r-s?"
notice that we can define a map to C by sending x to i. This is acutally an isomorphism - that is R[x]/{p} and C are actually the same field.
This looks like Chinese to me (and I am not oriental).
Ian Stewart's book on Galois Thoery is a good place to learn about this - unlike most university level texts this emphasizes the examples and works inside C most of the time.
Thanks for the reference. I will try to motivate myself through it (first I have to motivate myself to the library).
I realize that this addresses my question with a counterexample, so I do not dispute it. But, for the sake of future discussion, will infinite order polynomials be relevant? If so, then this seems like an example to show that not even the complex field is alg closed.
  • #34
I think I'll start a new thread for this, but to answer some specific questions.
1. 'omthe' is a typo that should read 'other'
2. No 0 is defined in C already, you just can't divide by it - check the definition of a field, F is a field if it is an abelian group, with identity 0 under operation +, and F, omitting 0, is also an abelian group under the operation *.
3. In some structure ( ring usually) we say x divides y (is a divisor of) if there some other z with x*z=y. So in the ring of integers mod 8, 2 divides 0 in a non-trivial way (obviously x.0=0 is a trivial statement), that is what we mean by zero-divisors (the non-trivial is implicit).
4. When I say it is not a good place to do arithmetic, I mean things like finding roots of ax+b=0 is not as easy as it ought to be, because usually we would say x= -b/a. However, when non-trivial zero divisors exist this isn't true, as we can no longer divide by a. I mean the multiplicative inverse for 2 does not exist in mod 8 arithmetic.
To convince yourself of what's going on, let's do mod 3 arithemetic, what is 1/2? It is by definition the thing that when multiplied by two gives 1, agreed? So we are seeking a y such that 2y=1 (mod 3). By inspection 2*2=4=1 mod 3, so 1/2 = 2! Really we ought not to write 1/2 as it is too suggestive, but instead write 2^{-1}
In cases where x*y=0 for non-zer x and y we cannot say 0/x =y and vice versa - or at least whilst you may write it, it is not valid as a mathematical statement. To see why, consider mod 16 arithmetic - 4*4=0 and 4*8=0, so you cannot define 0/4 - there are two possibitlities.
LOok out for a new posting.
  • · Replies 55 ·
  • · Replies 31 ·
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 47 ·
