Calculating focal length for aspherical lenses
The discussion revolves around calculating the focal length of aspherical lenses, exploring the complexities of their curvature compared to spherical lenses. Participants are interested in the application of the lensmaker's equation and how it applies to modeling aspherical lenses in computer simulations, as well as the implications for lens design and optical properties.
  • Some participants question how to apply the lensmaker's equation to aspherical lenses, noting that aspherical curvatures do not have a single radius.
  • There is a discussion about the plano-convex lens, with some confirming that the flat side can be considered to have an infinite radius.
  • Participants express uncertainty about the units for focal length in the lensmaker's equation, with some suggesting that consistency in units is what matters.
  • One participant mentions that aspheric lenses are typically used to correct aberrations and suggests approximating them with spherical models.
  • Another participant raises questions about the existence of a focal point for aspherical surfaces, noting that rays may converge at different points depending on their incident directions.
  • There are discussions about the mathematical definitions and equations related to aspherical lenses, including the sag of aspheres and their deviation from spherical shapes.
  • Some participants clarify that the term "aspherical" may have a more restricted technical meaning than initially assumed, focusing on specific shapes rather than any non-spherical form.
Participants generally do not reach a consensus on how to handle the calculations for aspherical lenses, with multiple competing views on the applicability of the lensmaker's equation and the nature of aspherical shapes. The discussion remains unresolved regarding the best approach to model these lenses.
There are limitations in the discussion regarding the assumptions made about the definitions of aspherical lenses and the mathematical steps involved in applying the lensmaker's equation. The complexity of aspherical shapes and their optical properties is acknowledged but not fully resolved.
CaptainBarbosa
How is it done? I've done a little research on Wikipedia and found the lensmaker's equation, but one of the values needed to compute focal length is the radius of the lens curvature. Strictly speaking, an aspherical curvature wouldn't have a set radius, would it? The reason I'm asking is because I'm trying to make a computer model of a lens and its fresnel equivalent. I can make a lens with an arbitrary curvature and convert this to a fresnel, but I would like to be able to model the curvature for specific focal points. (Given a fixed lens diameter.)
[Edit] For a plano-convex lens, I take it the flat side has infinite radius? Or am I totally screwed up in my thinking?
[Edit2] Also, what is the unit for focal length in the equation? Meters? Millimeters?
Science news on Phys.org
You are correct.
Doesn't matter, as long as you use the same units for the lens radii. A common unit of lens power (which is 1/f) is diopters; to get power in diopters you must measure focal length in meters.
Thanks for that. Anybody know an answer to my aspherical lens question?
[Edit] Here's the results of a test I did with my lens that I made just eyeballing the curve...
Um, hello? Anybody?
Due to the forum e-mail problem I had been using the other account, but I'll use this one from now on.
what am i looking at here? a picture ? cgi?
Yep, CGI. Here is a rendering of the lens I used in the foggy room test.
Could u show me the lensmaker's equation? Thanks
Doc Al said:
O,I got it, just the same as spheerical lens. BTW,could you show me an example about how to get the curvature R1 and R2 for aspherical lens by sending a email to <personal email removed>? This confuse me for quite a long time.Many thanks! Your help will be appreciated.
Wiki has a beginning stab at your answer: http://en.wikipedia.org/wiki/Radius_of_curvature_(optics )
In general I think aspheric lenses are used to correct for aberations so you might be able to come up with a close-fit spheric approximation to simplify things...
No, the lens maker's formula that I linked is meant for spherical lenses. I don't know of any simple formula for dealing with aspherical lenses. (Of course, you can treat it approximately as a spherical lens.)
For a plano-convex lens try:
r^2=(n^2-1)z^2 + 2f(n-1)z where r is radial and z is axial.
At z<<r, this gives a spherical shape with f=R/(n-1) where R is the radius of the sphere.
At r>>f, the shape is a straight line with r=sqrt(n^2-1)z
You can derive all of this by remembering that the idea of the lens is to produce constructive interference at the focal point, so all paths of an incoming parallel beam on the plano side should have the same number of wavelengths to the focal point independent of their position r.
How do you know that your a-spherical surface has a focal point, in the first place?
And how do you define it? The rays may converge in different points (if they do at all) for different incident directions.
I know that there are non-spherical shapes with focal points, but is this a general property, to expect for any shape?
nasu
Sorry, I forgot to mention that f is the distance to the focal point measured from the on-axis surface of the convex side. This formula was derived for a beam parallel to the axis. I would guess that the focal point gets smeared a little for incoming beams not parallel to the axis. Focusing is not a general property of a shape and in fact is only an approximation for a spherical surface (spherical aberration) but they are easy to make and understand. This aspherical lens has no spherical aberration.
Even though aspheric lenses have a varying radius of curvature, the lensmaker equation can be used, with fair accuracy, by using the lens radius at the center.
Prior to decent molded plastic optics, aspheres were rarely encountered. I don't have much information about them, but I can say the following:
Aspheres are typically characterized by their deviation from a reference sphere. If the sag for a sphere is given by
[tex]z =\frac{c\rho^{2}}{1+\sqrt{1-c^{2}\rho^{2}}}[/tex]
where c is the radius of curvature and [itex]\rho[/itex] the radial coordinate. The sag of an asphere is simply:
[tex]z =\frac{c\rho^{2}}{1+\sqrt{1-(1+k)c^{2}\rho^{2}}}[/tex]
where 'k' is the conic constant (k=0 for a sphere, k = -1 for a parabola, etc)
The most simple apsheric surface is a 'corrector plate', but large projector condensors can be aspheres. Aspheric elements are often used in telescope mirrors and conformal optics as well. The only relevant reference I have are two pages in O'Shea's 'Elements of Modern Optical Design', and he points to Chapter 3 of 'Applied optics and optical engineering' (R. Shannon and J.C. Wyant, eds)
Note that while use of aspheric elements can completely correct aberrations on axis, they fail off axis:coma and astigmatism are the most common.
Thank you for these details. Now I understand that by "a-spherical" you mean something more restricted that I did. I though that a-spherical means everything that is not a sphere, including an irregular kind of shape or with a periodic profile, or things like this. Or even something with a nice analytical profile which is not a conical section.
I suppose the OP had in mind something along the lines of your post above.
Maybe there is a difference in technical meaning between a-spherical and non-spherical?
  • · Replies 58 ·
9K
