Casey's First Day: Solving $\int t \sqrt{7t^2+12}dt$
  • Thread starter Thread starter Saladsamurai
The discussion revolves around the integral $\int t \sqrt{7t^2+12}dt$, focusing on the application of u-substitution in calculus.
  • The original poster attempts to use u=t for substitution but finds it complicated. Some participants suggest using the expression under the square root as the substitution instead. There is also a discussion about the terminology related to the term under the square root.
Participants are exploring different substitution strategies, with some guidance provided on choosing the appropriate u. The conversation indicates a progression towards understanding the substitution process, though there is still some confusion regarding the differentiation of dt.
There is mention of a potential misunderstanding regarding the proper choice of u and the corresponding differential, indicating that participants are still clarifying their assumptions and definitions.
Saladsamurai
First day of u subs...
[tex]\int t \sqrt{7t^2+12}dt[/tex]
I am assuming that u=t, but It is maiking a mess when I do that.
Just a hint please,
Casey
your first choice on a u-substitution with a rational number should always be the entire thing under the square root.
try u=7*t^2+12 instead
let u be the radican (is that the proper term? i forget) :D
do you mean like this?
If I do this, I get [tex]\int tudt[/tex] and [tex]du=\frac{dt}{2\sqrt{7t^2+12}}[/tex] ...right?
I think I am confused...
no just the 7t^2+12
if u=7t^2+12
what is dt=??
Oh..one sec...
Brain Cramp![tex]u=7t^2+12[/tex]
so
[tex]du=14tdt[/tex]
[tex]\int t u^{1/2} dt *14*\frac{1}{14}[/tex]
[tex]=\frac{1}{14}\int \sqrt{u}* du[/tex]
and I got it from here..
Thanks guys,
Casey
  • · Replies 22 ·
