Block move down the curved hill and hit attached block spring
The problem involves a 100-gram block moving down a curved hill and colliding elastically with a stationary 400-gram block attached to a spring. The discussion focuses on determining the maximum compression of the spring and the maximum height the first block reaches after the collision.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the conservation of energy as a potential approach and suggest providing a diagram and previous work to facilitate understanding. There is also mention of momentum equations related to the collision.
The discussion is ongoing, with some participants offering guidance on using conservation of energy and momentum principles. There is an emphasis on the need for additional information, such as diagrams and previous attempts, to better assist the original poster.
Participants note the importance of adhering to forum rules, which include providing diagrams and showing prior work. There is a suggestion that the original poster may be feeling overwhelmed by the problem.
cecico
A 100grams block is moving at 2m/s down the curved hill. The block slides along the smooth surface and collides elastically with the 400gram block. The 400gram block is initially at rest and is attached to an ideal spring with spring constant of 500N/m
a)Find the maximum distance the spring compresses
b)Find the maximum height the 100gram block reaches after the collision.
I have no idea with this problem...someone help me...
Conservation of energy.
Give that a go - let us know what happens.
In order to receive help with this problem I suggest that you
a) Provide a diagram
b) Show the work you have tried thus far. Forum rules.
dont know for sure but collisions usually go by the equation
m1u1 + m2u2 = m1v1 +m2v2
m1 being mass 1 = 0.1kg
m2 being 0.4 kg
u1 being =2 m/s
u2 = 0 m/s as its stationary
then work out the momentum of the second block as this would be equal to the force on the spring which would follow the equation
F = kx
where k is 500 N/m and thus u have the distance x
and then its pray someone with more brains than me gives u an answer otherwise ul b stuck on it all night long...lol...sorry mate
how to post diagram?
Scanner, photograph, MS Paint. Free account at Photobucket.com will host images.
I know it's a little work... but it will get your question answered much quicker.
