Analysis problem for my research
  • Context: Graduate
  • Thread starter Thread starter blackbelt5400
    Analysis Research
The discussion revolves around a research problem in potential theory, specifically analyzing the behavior of the function h(t) = f(t) + g(t) under certain conditions. Participants are tasked with proving that h'(t) has at most three zeros based on given properties of the functions f and g.
  • One participant presents the problem and conditions for h(t) and seeks to prove that h'(t) has at most three zeros.
  • Another participant suggests an alternative formulation of the problem using H(t) = F(t) - G(t) and claims to see at most two zeros from a graphical example, but expresses uncertainty about their mathematical expertise.
  • Some participants question whether f and g are analytic or merely smooth functions, suggesting that if they are only smooth, counterexamples could be constructed where h' has infinitely many zeros.
  • One participant describes the functions as subharmonic and provides a specific physical context involving potential functions from charges, detailing the conditions under which they need to show that h'(t) has at most two or three zeros.
  • Another participant proposes constructing f in three separate pieces and smoothing it with a mollifier to address potential issues with continuity and differentiability.
  • Concerns are raised about the possibility of g and -f being parallel over an interval, which could lead to complications in determining the zeros of h'.
  • A later reply discusses the implications of having convergent Taylor series for -f and g, suggesting that equality on an interval would imply equality everywhere under certain conditions.
Participants express differing views on the nature of the functions f and g, with some proposing that counterexamples exist while others provide specific contexts that may limit the behavior of h'. The discussion remains unresolved regarding the exact conditions under which h'(t) has a limited number of zeros.
Participants note limitations regarding the assumptions about the functions f and g, particularly concerning their analyticity and smoothness. There is also mention of the dependence on specific configurations in the physical context of potential theory.
blackbelt5400
This is not a homework problem. I've encountered something in my research in potential theory, and I need to prove the following.
Given:
h(t) = f(t) + g(t),
f '(t) < 0 for all t,
g'(t) > 0 for all t, and g'(t) is monotonically increasing,
f '(0) = 0,
g'(0) > 0,
f '(t) has exactly one minimum, and [tex]\lim_{t\to\infty}f'(t) = 0[/tex].
Show that h'(t) has at most three zeros.
Given:
h(t) = f(t) + g(t),
f '(0) = 0,
g'(0) > 0,
Replace it by:
H(t)=F(t)-G(t)
H(t)=h'(t), F(t)=f'(t), G(t)=-g'(t)
F(t)<0, F(0)=0, G(t)<0, G(0)<0, G(t) monotonically decreasing
I see at most 2 zeros from graph example.
But I am not a mathmatical professional so can't help u walk it through.
Hope this can help.
are f,g analytic, or maybe polynomials? if they are only smooth functions, it seems fairly easy to construct counterexamples where h' has infinitely many zeroes.
just let g = e^x, and let the graph of -f be parallel to, even equal to, the graph of g, over some interval like 1 < x < 2. then for x > 2 let the graph of -f have a flex (unique max of -f') and let -f' start to decrease toward zero as x--> infinity.
for x<1, just let graph -f straighten up to the left faster than that of g, so it becoems horizontal at x = 0, to get -f' = 0.
then -f' = g' for 1 < x < 2, so h' = f' + g' = 0 for all x: 1<x<2.
The most I can say is that they are subharmonic.
These are potential functions using the Newtonian kernel. Particularly, I've placed two positive charges on the x-axis at (0,0) and (1,0), with the third positive charge somewhere in the upper half-plane. Choose 0<c<1, and let [tex]\vec{v}[/tex] be the line segment originating at c directed into the upper half-plane.
Parameterize the potential on this vector with x(t) = c, y(t) = t.
Then the potential on this vector is given by h(t) = f(t)+g(t), where f(t) is the potential from the two charges on the x-axis, and g(t) is the potential from the third charge in the upper half-plane.
Clearly f '(t)<0, and f '(0)=0. I've proven that f '(t) also has exactly one minimum. Also, g'(0)>0, and if this line segment is chosen to be an altitude of the triangle formed by the three charges, then g(t) is convex and increasing. In this case, I need to show that h'(t) has at most two zeros.
If the vector is not an altitude of the triangle, then you lose the convexity of g(t). It will still be true that g'(t)>0 for all t in [0,y_3) (where (x_3,y_3) is the coordinate of the third charge). I can show that g'(t) is increasing initially. However, g'(y_3)=0, so g takes a max and is therefore concave down after some point.
In this case, the problem changes to showing that h'(t) has at most three zeros.
To create the function mathwonk said, you can create f in 3 separate peices - f in [0,1], in (1,2], and in (2,infty).
At this point it will have "corners" where the peices meet up. Then convolve it with a thin mollifier to smooth out the corners.
what goes wrong in my counterexamples is that it is possible for g and -f to be parallel for an entire interval, and then deviate off that interval.
so you need some kind of fact that they are determined by their values on an interval,
some kind of principle of analytic continuation. i believe harmonic functions have this (since they are locally the real parts of analytic functions) , but i do not remember about subharmonic ones.
Right. If -f and g have convergent taylor series everywhere, then being equal on an interval like [1,2] would imply that they are equal everywhere (since their taylor series'es about a point in the interval would be equal).
  • · Replies 24 ·
