Simple frictional forces and forces on boxes
  • Thread starter Thread starter metsjetsfan
    Forces
The discussion revolves around two physics problems involving forces and friction. The first problem concerns the contact forces between three boxes being pushed by an external force, while the second problem addresses the force of friction acting on a box resting on a horizontal surface.
  • Participants explore the calculation of contact forces between boxes, questioning the correct application of mass and acceleration. They also discuss the concept of static and kinetic friction in relation to applied forces.
Some participants express confusion about the underlying concepts and calculations, while others provide clarifications and affirmations of the reasoning presented. There is an ongoing exploration of the friction problem, with participants seeking further guidance.
Participants mention a lack of confidence in the teacher's guidance and the need for additional resources to understand the concepts better. There is a reference to specific values for coefficients of friction and the setup of the problems, indicating constraints in the information provided.
metsjetsfan
First question: A force of magnitude 7.5 N pushes three boxes with masses m1= 1.3 kg, m2=3.2 kg, and m3=4.9 kg. Find the contact force between
a-boxes 1 and 2
b-boxes 2 and 3
There is a diagram, so I'll try to describe it...it's pretty simple. The boxes are just sitting next to each other. From left to right, Box 1 is next to box 2 which is next to box 3, and the force is being applied to box 3 from the right.
Second question: A 10 kg box rests on a horizontal floor. The coefficient of static friction is .4 and the coefficient of kinetic friction is .3. Determine the force of friction acting on the box if a horizontal external applied force is exerted on it of magnitude:
a) 0 N b) 10 N c) 20 N d) 38 N e) 40 N
for question 1, F=ma
for question 2, f=(coefficient of static/kinetic friction) * (normal force)
First question: I really just don't understand the concept behind this. At first I thought that I needed to find the acceleration of the entire system, so
7.5 = (4.9+3.2+1.3) * a
a= .798
But then I'm not sure if I'm right with where I go now. I did:
let F= contact force between boxes 1 and 2 and
1.3 * .798= 7.5 N - F
F= 6.5 N
The answer is supposedly 1 N
for part b, I did pretty much the same thing except it was the mass of box 2, or 3.2, instead of 1.3.
The answer for b is 3.59 N
my main question is how do I know which box I use as the mass, and are these answers even right. My physics teacher is horrible, and I have no confidence in her answers as she has proven to me before...
For question 2, is the force of friction just the same as the applied force up until the max static friction or 9.8 * 10 * .4 which is 39.2. If so, then how do I get the answer for when the force is 40 N? Is it just 9.8 * 10 * .3?
Thanks for any help guys...this is my first time asking for an answer, and probably not the last time since my teacher is so incompetent...
a= .798
Good.
F= 6.5 N
The force is being applied from the right, so the contact force between boxes 1 and 2 is just enough to cause box 1's acceleration to be 0.798...does that help?
For part(b), the force is just enough to push box 2 and box 1 at an acceleration of 0.798 :wink:
OOOOOOOOH, I understand now!
So force between box 1 and 2 is:
f=ma=1.3 * .798= 1
and force between box 2 and 3 is:
f= (1.3+3.2) * .798 = 3.59 N
IS THAT IT?
Also, could you answer my second question involving frictional forces?
Thanks a lot!
f=ma=1.3 * .798= 1
IS THAT IT?
Thanks a lot!
Looks good! :smile:
...now on to the second question:
seems reasonable to me!:approve:
I guess your physics teacher can't be that bad after all :wink:
Oh no...my teacher didn't teach me any of that. She just gave us the equation f=uk * N. I had to guess with the rest by getting my own textbook...
Thanks so much...you made everything clear with one sentence!
Your welcome; good luck with your studies! :smile:
  • · Replies 21 ·
